Email notifications failing
QPII
Post by QPII »
Im having issues sending notifications on my set up of Nagios 4.4.1
Which mail returns
/usr/bin/mail
In my command.cfg I have
        command_name    notify-host-by-email
        command_line    /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
        command_name    notify-service-by-email
        command_line    /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /usr/bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
And in my event log this is the result when I force a msg from the host. (I have used **** to remove the actual email address, but have verified and reverified the email address is not the issue)
[11-22-2019 15:27:42] wproc: Core Worker 2038: job 1 (pid=2073): Dormant child reaped
Informational Message[11-22-2019 15:27:42] Warning: Notifying contact 'nagiosadmin' of host 'TESTEMAIL' by command '/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: CUSTOM\nHost: TESTEMAIL\nState: DOWN\nAddress: 10.1.17.17\nInfo: CRITICAL - Host Unreachable (10.1.17.17)\n\nDate/Time: Fri Nov 22 15:27:11 CST 2019\n" | /usr/bin/mail -s "** CUSTOM Host Alert: TESTEMAIL is DOWN **" ****@***.com' timed out after 0.00 seconds
Informational Message[11-22-2019 15:27:42] wproc: early_timeout=1; exited_ok=0; wait_status=0; error_code=62;
Informational Message[11-22-2019 15:27:42] wproc: host=TESTEMAIL; service=(none); contact=nagiosadmin
Informational Message[11-22-2019 15:27:42] wproc: NOTIFY job 1 from worker Core Worker 2038 timed out after 31.03s
Informational Message[11-22-2019 15:27:41] wproc: Core Worker 2038: job 1 (pid=2073) timed out. Killing it
Host Notification[11-22-2019 15:27:11] HOST NOTIFICATION: nagiosadmin;TESTEMAIL;CUSTOM (DOWN);notify-host-by-email;CRITICAL - Host Unreachable (10.1.17.17);Nagios Admin;TEST
External Command[11-22-2019 15:27:11] EXTERNAL COMMAND: SEND_CUSTOM_HOST_NOTIFICATION;TESTEMAIL;0;Nagios Admin;TEST
I genuinely appreciate any ideas you guys have. Thank you
Re: Email notifications failing
It's showing the command timed out
Can you run this from the CLI adding the email back in for ****@***.com?
su nagios
QPII
Post by QPII »
It was failing from the CLI as well and that ended up pointing me in the correct direction.
Thank you so much!
QPII wrote:It was failing from the CLI as well and that ended up pointing me in the correct direction.
Thank you so much!
Great!
May we lock the thread?
QPII
Post by QPII »
Yes
Thanks again!
QPII wrote:Yes
Thanks again!
Great!\
Locking thread
