I've been fiddling with a script to perform a silent install of NSClient++ (version 0.5.2.35). At the moment, the command I'm running to perform the actual installation is:
msiexec /qn /l* log.txt /i NSCP-0.5.2.35-x64.msiCode: Select all
; BIND TO ADDRESS - Allows you to bind server to a specific local address. This has to be a dotted ip address not a host name. Leaving this blank will bind to all available IP addresses.
bind to = UNKNOWNI realize this may be a question better suited to the NSClient++ forum, but the site's been down for at least a couple of days. I figured I'd post it here as it is related to Nagios, and someone might happen to know how to fix this.
Thank you very much.
