Nagios Repos
dbcummings
Nagios Repos
Post by dbcummings »
I have noticed that the Nagios repos for RHEL and Oracle are the same. Is that correct?
Re: Nagios Repos
Our content is the same in our repos, however
If you are using Oracle Linux 7, remove any pre-installed mysql packages. Then run the following to enable the optional repo and then continue below.
yum install yum-utils -y
yum-config-manager --enable ol7_optional_latest
dbcummings
Re: Nagios Repos
Ok. Thank you. You can lock the post.
Re: Nagios Repos
dbcummings wrote:Ok. Thank you. You can lock the post.
great!
Locking
