User account can log into application
brucej543
Post by brucej543 »
Nagios XI 5.6.5 I have one user account (actually mine) in which has Admin authorization level the gets invalid username or password when trying to log into nagios. Last successful login was on 11/20 with a logout on 11/21. All users accounts are validated through the LDAP/AD integration. This account was used to build 90% of the base system, not sure if there would be any issues to delete and re-add the account.
Please let me know what information is need to research this issue.
cdienger
Re: User account can log into application
Post by cdienger »
Debugging can be enabled following the steps in https://support.nagios.com/kb/article/a ... n-600.html.
I would also recommend enabling the "Allow local login if auth server login fails" option on the account, setting its password, and seeing if that allows you to login with it.
brucej543
Post by brucej543 »
Hi cdienger , this thread can be closed. It was a user error. the Debug information provide the information. Thanks
brucej543 wrote:Hi cdienger , this thread can be closed. It was a user error. the Debug information provide the information. Thanks
great!
Locking thread
