Hi Team,
We have configured the Network devices for monitoring thru SNMP, For some of the ports we are getting performance graphs but fro some other ports we are not getting any performance graphs,Please do the needful .
showing in/out bandwidth utilization but no performance graphs are generating.
Unable to get the performance Graph
Re: Unable to get the performance Graph
Can you post the MRTG configuration file? You can get it from /etc/mrtg/conf.d/, and the file name should just be the name or IP of the device you are monitoring.
What version of XI are you running?
inas.labib
Hi Team,
I have attached the Configuration file .
by Replacing Device IP hostname username authentication protocol and password
Please go through it and let us know.
We are using Nagios XI 5.2.2 version .
For your info we are getting same result for NagiosXI 5.5.9 in another nagios xi .
Perfect, thank you. Also can you tell me the name of a port that is giving you performance graph data, and a port that is not giving you performance graph data?
inas.labib
we are getting performance graph for TenGigabitEthernet1/1
not getting performance graph for TenGigabitEthernet1/6
please do the needful as early as possible
inas.labib
Hi Team
Please do the needful.
Apologies for the delay. Our office was closed for the holiday.
I am looking at TenGigabitEthernet1/1, and it looks like it does not have an Ethernet ID, like 1/6 does.
Eth: '30-78-61-38-39-64-32-31-39-61-39-35-38-35' ###
Eth: 'No Ethernet Id' ###
That's really the only difference I can see in the files. But 1/6 is the one that isn't reporting, where 1/1 is reporting. So I think that's fine.
Can you PM me your system profile? Just go to Admin -> System Profile -> Download Profile. I'd like to see if there are any differences in how the commands are setup.
inas.labib
Hi
I am unable to download the system profile throwing error
PROFILE BUILD FAILED
Array
CODE: 1
so i copied in note pad and attached PFA.
Thanks.
Moderator's Note: The profile has been shared with the support team but has been removed from the public forum.
Array
CODE: 1
Thanks.
benjaminsmith
Hello @inas.labib,
The problem is typically the result of an incorrect sudoers file. Please follow the instructions below to resolve and try sending the profile once more. Thanks.
Nagios XI - Profile Build Failed
inas.labib
We have followed the above mentioned article ,
Sudoers files are same even though we are getting same error.
