Update unit for Windows PerfMon counters
mouch
Post by mouch »
Hi Nagios Community,
I've been struggling for few days already trying to fix a non critical but annoying issue I'm facing with services that are checking windows PerfMon counters.
I started to use them following the example that is included in the Windows Server Monitoring Wizard.
In this wizard, we can pick for example the Server Work Queue - right after its creation, the service is returning data (aligned with the server counter, good) but I cannot find a way to update the unit of the result.
It is always displayed as a % where I would like to change it to whatever I need (time, B, count, whatever). Do you know how to achieve this?
Please find below few pictures of the test service I created from the Windows Server Configuration Wizard
Performance Chart - not showing data as this is a new service but still trying to display % only
Run test service command
Thanks for your time and support on this!
cdienger
Re: Update unit for Windows PerfMon counters
Post by cdienger »
The images didn't make it through. Please try attaching them again.
mouch
Post by mouch »
Hello cdienger,
Here is the output when running the test command
Current work queue (an indication of processing load) is 0  | 'Current work queue (an indication of processing load) is %.f '=0.000000%;4.000000;7.000000;
We can already see here the % (whereas it should have no unit)
And here is the graph outputted (hopefully that time you will see the picture)
https://imgur.com/4DqRKCK
Thanks for your support
Edit: I removed the img balise, it seems like the link is working but I cannot get it rendered with the balise. You will have to copy the URL if you want to view the picture
ssax
Dreams In Code
Post by ssax »
Change the command from:
-l "\\Server Work Queues(0)\\Queue Length","Current work queue (an indication of processing load) is %.f "
To:
-l "\\Server Work Queues(0)\\Queue Length","Current work queue (an indication of processing load) is","YOURUNIT"
Does that work for you?
mouch
Post by mouch »
Hi ssax and thanks for your reply.
Unfortunatly, adding the unit with your propose formatting is not changing anything (whatever unit I choose (tried X,s,ms))
See below my service testing output
[XXX]$ /usr/local/nagios/libexec/check_nt -H YYY -s ZZZ -p 12489 -v COUNTER -l "\\Server Work Queues(0)\\Queue Length","Current work queue (an indication of processing load) is %.f ","ms" -w 4 -c 7
Update:
I removed the %.f as you suggested - did not notice this change at first sight
The output is now OK with unit update!
Current work queue (an indication of processing load) is  = 0.00 COUNT | 'Current work queue (an indication of processing load) is '=0.000000COUNT;4.000000;7.000000;
The graph also is updated. Thanks for your support on this one
mouch wrote:Hi ssax and thanks for your reply.
Update:
Great!
Locking thread
