Error: Package: php72w-devel-7.2.24-1.w7.x86_64 (webtatic)
Requires: libargon2.so.0()(64bit)
Error: Package: nagiosxi-deps-el7-5.6.8-1.noarch (/nagiosxi-deps-el7-5.6.8-1.noarch)
Requires: snmptt
Error: Package: libmcrypt-devel-2.5.8-9.3.el7rhgs.x86_64 (rh-gluster-3-for-rhel-7-server-rpms)
Requires: libmcrypt = 2.5.8-9.3.el7rhgs
Installed: libmcrypt-2.5.8-13.el7.x86_64 (@epel)
libmcrypt = 2.5.8-13.el7
Available: libmcrypt-2.5.8-9.3.el7rhgs.x86_64 (rh-gluster-3-for-rhel-7-server-rpms)
Requires: freetds-devel
Requires: shellinabox
Error: Package: php72w-cli-7.2.24-1.w7.x86_64 (webtatic)
Error: Package: mod_php72w-7.2.24-1.w7.x86_64 (webtatic)
Requires: python-pip
Error: nagiosxi-deps-el7 conflicts with nrpe-3.2.1-8.el7.x86_64
Error: php72w-common conflicts with php-common-5.4.16-46.1.el7_7.x86_64
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Loaded plugins: langpacks, product-id, search-disabled-repos, subscription-
: manager
Cleaning repos: nagios-base nagiosxi-deps nux-dextop remi-safe
: rh-gluster-3-for-rhel-7-server-rpms rhel-7-server-optional-rpms
: rhel-7-server-rpms webtatic
Other repos take up 1.3 G of disk space (use --verbose for details)
: manager
Examining /apps/nagiosxi/nagiosxi/nagiosxi-deps-el7-5.6.8-1.noarch.rpm: nagiosxi-deps-el7-5.6.8-1.noarch
Marking /apps/nagiosxi/nagiosxi/nagiosxi-deps-el7-5.6.8-1.noarch.rpm to be installed
Resolving Dependencies
--> Running transaction check
---> Package nagiosxi-deps-el7.noarch 0:5.6.8-1 will be installed
--> Processing Dependency: automake for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: autoconf for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: dstat for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: fping for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: gd-devel for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: graphviz for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: graphviz-gd for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: httpd for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: libmcrypt-devel for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: mod_ssl for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: snmptt for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: net-snmp-perl for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: nmap for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: numpy for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: openldap-devel for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl(CPAN) for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl(Crypt::Rijndael) for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl(Crypt::SSLeay) for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl(HTTP::Cookies) for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl(HTTP::Request::Common) for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-LWP-Protocol-https for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-Mail-IMAPClient for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl(XML::Parser) for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl(XML::Simple) for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl(Class::Accessor) for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl(Test::Simple) for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-Params-Validate for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-Config-Tiny for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-Math-Calc-Units for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-Net-DNS for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-Net-SNMP for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-Number-Format for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php-gd for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php-pear for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php-pecl-ssh2 for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php-pgsql for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php-snmp for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php-xml for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php-mbstring for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php-ldap for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php-devel for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: php-imap for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: postgresql-server for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: postgresql-libs for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: python-simplejson for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: python-pymssql for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: rpmdevtools for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: rrdtool for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: rrdtool-perl for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: rrdtool-python for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: subversion for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: xinetd for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: python-devel for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: python-pip for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: freetds-devel for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: tftp for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-IO-Socket-INET6 for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-SNMP_Session for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-Socket6 for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: ipa-gothic-fonts for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: ipa-mincho-fonts for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: ipa-pgothic-fonts for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: ipa-pmincho-fonts for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: perl-Sys-Syslog for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: ansible for package: nagiosxi-deps-el7-5.6.8-1.noarch
--> Processing Dependency: shellinabox for package: nagiosxi-deps-el7-5.6.8-1.noarch
---> Package ansible.noarch 0:2.3.2.0-1.el7 will be installed
--> Processing Dependency: python-crypto for package: ansible-2.3.2.0-1.el7.noarch
--> Processing Dependency: python-httplib2 for package: ansible-2.3.2.0-1.el7.noarch
--> Processing Dependency: python-jinja2 for package: ansible-2.3.2.0-1.el7.noarch
--> Processing Dependency: python-paramiko for package: ansible-2.3.2.0-1.el7.noarch
--> Processing Dependency: sshpass for package: ansible-2.3.2.0-1.el7.noarch
---> Package autoconf.noarch 0:2.69-11.el7 will be installed
--> Processing Dependency: m4 >= 1.4.14 for package: autoconf-2.69-11.el7.noarch
---> Package automake.noarch 0:1.13.4-3.el7 will be installed
--> Processing Dependency: perl(Thread::Queue) for package: automake-1.13.4-3.el7.noarch
---> Package dstat.noarch 0:0.7.2-12.el7 will be installed
---> Package fping.x86_64 0:3.10-4.el7 will be installed
---> Package gd-devel.x86_64 0:2.0.35-26.el7 will be installed
--> Processing Dependency: fontconfig-devel for package: gd-devel-2.0.35-26.el7.x86_64
--> Processing Dependency: freetype-devel for package: gd-devel-2.0.35-26.el7.x86_64
--> Processing Dependency: libX11-devel for package: gd-devel-2.0.35-26.el7.x86_64
--> Processing Dependency: libXpm-devel for package: gd-devel-2.0.35-26.el7.x86_64
--> Processing Dependency: libjpeg-devel for package: gd-devel-2.0.35-26.el7.x86_64
--> Processing Dependency: libpng-devel for package: gd-devel-2.0.35-26.el7.x86_64
---> Package graphviz.x86_64 0:2.30.1-21.el7 will be installed
--> Processing Dependency: urw-fonts for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libICE.so.6()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libSM.so.6()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libXaw.so.7()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libXext.so.6()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libXmu.so.6()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libXrender.so.1()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libXt.so.6()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libatk-1.0.so.0()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libcairo.so.2()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libgdk-x11-2.0.so.0()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libgs.so.9()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libgtk-x11-2.0.so.0()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libpango-1.0.so.0()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libpangocairo-1.0.so.0()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: libpangoft2-1.0.so.0()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
--> Processing Dependency: librsvg-2.so.2()(64bit) for package: graphviz-2.30.1-21.el7.x86_64
---> Package graphviz-gd.x86_64 0:2.30.1-21.el7 will be installed
---> Package httpd.x86_64 0:2.4.6-90.el7 will be installed
---> Package ipa-gothic-fonts.noarch 0:003.03-5.el7 will be installed
---> Package ipa-mincho-fonts.noarch 0:003.03-5.el7 will be installed
---> Package ipa-pgothic-fonts.noarch 0:003.03-5.el7 will be installed
---> Package ipa-pmincho-fonts.noarch 0:003.03-5.el7 will be installed
---> Package libmcrypt-devel.x86_64 0:2.5.8-9.3.el7rhgs will be installed
--> Processing Dependency: libmcrypt = 2.5.8-9.3.el7rhgs for package: libmcrypt-devel-2.5.8-9.3.el7rhgs.x86_64
---> Package mod_php72w.x86_64 0:7.2.24-1.w7 will be installed
--> Processing Dependency: libargon2.so.0()(64bit) for package: mod_php72w-7.2.24-1.w7.x86_64
---> Package mod_ssl.x86_64 1:2.4.6-90.el7 will be installed
---> Package net-snmp-perl.x86_64 1:5.7.2-43.el7 will be installed
---> Package nmap.x86_64 2:6.47-1 will be installed
---> Package numpy.x86_64 1:1.7.1-13.el7 will be installed
--> Processing Dependency: python-nose for package: 1:numpy-1.7.1-13.el7.x86_64
--> Processing Dependency: libgfortran.so.3()(64bit) for package: 1:numpy-1.7.1-13.el7.x86_64
--> Processing Dependency: liblapack.so.3()(64bit) for package: 1:numpy-1.7.1-13.el7.x86_64
--> Processing Dependency: libquadmath.so.0()(64bit) for package: 1:numpy-1.7.1-13.el7.x86_64
--> Processing Dependency: libtatlas.so.3()(64bit) for package: 1:numpy-1.7.1-13.el7.x86_64
---> Package openldap-devel.x86_64 0:2.4.44-21.el7_6 will be installed
--> Processing Dependency: cyrus-sasl-devel(x86-64) for package: openldap-devel-2.4.44-21.el7_6.x86_64
---> Package perl-CPAN.noarch 0:1.9800-294.el7_6 will be installed
--> Processing Dependency: perl(Digest::SHA) for package: perl-CPAN-1.9800-294.el7_6.noarch
--> Processing Dependency: perl(local::lib) for package: perl-CPAN-1.9800-294.el7_6.noarch
---> Package perl-Class-Accessor.noarch 0:0.34-12.el7 will be installed
---> Package perl-Config-Tiny.noarch 0:2.14-7.el7 will be installed
---> Package perl-Crypt-Rijndael.x86_64 0:1.12-1.el7 will be installed
---> Package perl-Crypt-SSLeay.x86_64 0:0.64-5.el7 will be installed
---> Package perl-HTTP-Cookies.noarch 0:6.01-5.el7 will be installed
--> Processing Dependency: perl(HTTP::Date) >= 6 for package: perl-HTTP-Cookies-6.01-5.el7.noarch
---> Package perl-HTTP-Message.noarch 0:6.06-6.el7 will be installed
--> Processing Dependency: perl(Encode::Locale) >= 1 for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(LWP::MediaTypes) >= 6 for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(URI) >= 1.10 for package: perl-HTTP-Message-6.06-6.el7.noarch
--> Processing Dependency: perl(IO::HTML) for package: perl-HTTP-Message-6.06-6.el7.noarch
---> Package perl-IO-Socket-INET6.noarch 0:2.69-5.el7 will be installed
---> Package perl-LWP-Protocol-https.noarch 0:6.04-4.el7 will be installed
--> Processing Dependency: perl(IO::Socket::SSL) >= 1.54 for package: perl-LWP-Protocol-https-6.04-4.el7.noarch
--> Processing Dependency: perl(Mozilla::CA) >= 20110101 for package: perl-LWP-Protocol-https-6.04-4.el7.noarch
--> Processing Dependency: perl(Net::HTTPS) >= 6 for package: perl-LWP-Protocol-https-6.04-4.el7.noarch
--> Processing Dependency: perl(LWP::Protocol::http) for package: perl-LWP-Protocol-https-6.04-4.el7.noarch
---> Package perl-Mail-IMAPClient.noarch 0:3.37-1.el7 will be installed
--> Processing Dependency: perl(Parse::RecDescent) for package: perl-Mail-IMAPClient-3.37-1.el7.noarch
---> Package perl-Math-Calc-Units.noarch 0:1.07-9.el7 will be installed
---> Package perl-Net-DNS.x86_64 0:0.72-6.el7 will be installed
--> Processing Dependency: perl(Digest::HMAC_MD5) >= 1 for package: perl-Net-DNS-0.72-6.el7.x86_64
---> Package perl-Net-SNMP.noarch 0:6.0.1-7.el7 will be installed
--> Processing Dependency: perl(Digest::SHA1) for package: perl-Net-SNMP-6.0.1-7.el7.noarch
--> Processing Dependency: perl(Digest::MD5) for package: perl-Net-SNMP-6.0.1-7.el7.noarch
--> Processing Dependency: perl(Crypt::DES) for package: perl-Net-SNMP-6.0.1-7.el7.noarch
---> Package perl-Number-Format.noarch 0:1.73-14.el7 will be installed
---> Package perl-Params-Validate.x86_64 0:1.08-4.el7 will be installed
--> Processing Dependency: perl(Module::Implementation) for package: perl-Params-Validate-1.08-4.el7.x86_64
---> Package perl-SNMP_Session.noarch 0:1.13-5.el7 will be installed
---> Package perl-Socket6.x86_64 0:0.23-15.el7 will be installed
---> Package perl-Sys-Syslog.x86_64 0:0.33-3.el7 will be installed
---> Package perl-Test-Simple.noarch 0:0.98-243.el7 will be installed
---> Package perl-XML-Parser.x86_64 0:2.41-10.el7 will be installed
---> Package perl-XML-Simple.noarch 0:2.20-5.el7 will be installed
--> Processing Dependency: perl(XML::NamespaceSupport) for package: perl-XML-Simple-2.20-5.el7.noarch
--> Processing Dependency: perl(XML::SAX) for package: perl-XML-Simple-2.20-5.el7.noarch
---> Package php-pear.noarch 1:1.9.4-21.el7 will be installed
--> Processing Dependency: php-posix for package: 1:php-pear-1.9.4-21.el7.noarch
---> Package php-pecl-ssh2.x86_64 0:0.12-1.el7 will be installed
---> Package php72w-devel.x86_64 0:7.2.24-1.w7 will be installed
--> Processing Dependency: php72w-cli(x86-64) = 7.2.24-1.w7 for package: php72w-devel-7.2.24-1.w7.x86_64
--> Processing Dependency: libargon2.so.0()(64bit) for package: php72w-devel-7.2.24-1.w7.x86_64
---> Package php72w-gd.x86_64 0:7.2.24-1.w7 will be installed
--> Processing Dependency: php72w-common(x86-64) = 7.2.24-1.w7 for package: php72w-gd-7.2.24-1.w7.x86_64
---> Package php72w-imap.x86_64 0:7.2.24-1.w7 will be installed
--> Processing Dependency: libc-client.so.2007()(64bit) for package: php72w-imap-7.2.24-1.w7.x86_64
---> Package php72w-ldap.x86_64 0:7.2.24-1.w7 will be installed
---> Package php72w-mbstring.x86_64 0:7.2.24-1.w7 will be installed
---> Package php72w-pgsql.x86_64 0:7.2.24-1.w7 will be installed
--> Processing Dependency: php72w-pdo(x86-64) = 7.2.24-1.w7 for package: php72w-pgsql-7.2.24-1.w7.x86_64
---> Package php72w-snmp.x86_64 0:7.2.24-1.w7 will be installed
---> Package php72w-xml.x86_64 0:7.2.24-1.w7 will be installed
---> Package postgresql-libs.x86_64 0:9.2.24-1.el7_5 will be installed
---> Package postgresql-server.x86_64 0:9.2.24-1.el7_5 will be installed
--> Processing Dependency: postgresql(x86-64) = 9.2.24-1.el7_5 for package: postgresql-server-9.2.24-1.el7_5.x86_64
---> Package python-devel.x86_64 0:2.7.5-86.el7 will be installed
--> Processing Dependency: python-rpm-macros > 3-30 for package: python-devel-2.7.5-86.el7.x86_64
--> Processing Dependency: python2-rpm-macros > 3-30 for package: python-devel-2.7.5-86.el7.x86_64
---> Package python-pymssql.x86_64 0:2.1.1-1.el7 will be installed
---> Package python-simplejson.x86_64 0:3.5.3-1.el7ost will be installed
---> Package rpmdevtools.noarch 0:8.3-5.el7 will be installed
--> Processing Dependency: rpm-build >= 4.4.2.3 for package: rpmdevtools-8.3-5.el7.noarch
---> Package rrdtool.x86_64 0:1.4.9-1.el7 will be installed
--> Processing Dependency: dejavu-serif-fonts for package: rrdtool-1.4.9-1.el7.x86_64
--> Processing Dependency: dejavu-lgc-sans-mono-fonts for package: rrdtool-1.4.9-1.el7.x86_64
--> Processing Dependency: dejavu-lgc-sans-fonts for package: rrdtool-1.4.9-1.el7.x86_64
---> Package rrdtool-perl.x86_64 0:1.4.9-1.el7 will be installed
---> Package rrdtool-python.x86_64 0:1.4.9-1.el7 will be installed
---> Package subversion.x86_64 0:1.7.14-14.el7 will be installed
--> Processing Dependency: subversion-libs(x86-64) = 1.7.14-14.el7 for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libneon.so.27()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_client-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_delta-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_diff-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_fs-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_fs_base-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_fs_fs-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_fs_util-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_ra-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_ra_local-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_ra_neon-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_ra_svn-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_repos-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_subr-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
--> Processing Dependency: libsvn_wc-1.so.0()(64bit) for package: subversion-1.7.14-14.el7.x86_64
---> Package tftp.x86_64 0:5.2-22.el7 will be installed
---> Package xinetd.x86_64 2:2.3.15-13.el7 will be installed
---> Package atk.x86_64 0:2.28.1-1.el7 will be installed
---> Package atlas.x86_64 0:3.10.1-12.el7 will be installed
---> Package cairo.x86_64 0:1.15.12-4.el7 will be installed
--> Processing Dependency: libEGL.so.1()(64bit) for package: cairo-1.15.12-4.el7.x86_64
--> Processing Dependency: libGL.so.1()(64bit) for package: cairo-1.15.12-4.el7.x86_64
---> Package cyrus-sasl-devel.x86_64 0:2.1.26-23.el7 will be installed
--> Processing Dependency: cyrus-sasl(x86-64) = 2.1.26-23.el7 for package: cyrus-sasl-devel-2.1.26-23.el7.x86_64
---> Package dejavu-lgc-sans-fonts.noarch 0:2.33-6.el7 will be installed
---> Package dejavu-lgc-sans-mono-fonts.noarch 0:2.33-6.el7 will be installed
---> Package dejavu-serif-fonts.noarch 0:2.33-6.el7 will be installed
---> Package fontconfig-devel.x86_64 0:2.13.0-4.3.el7 will be installed
--> Processing Dependency: pkgconfig(uuid) for package: fontconfig-devel-2.13.0-4.3.el7.x86_64
---> Package freetype-devel.x86_64 0:2.8-14.el7 will be installed
---> Package gtk2.x86_64 0:2.24.31-1.el7 will be installed
--> Processing Dependency: libXrandr >= 1.2.99.4-2 for package: gtk2-2.24.31-1.el7.x86_64
--> Processing Dependency: gtk-update-icon-cache for package: gtk2-2.24.31-1.el7.x86_64
--> Processing Dependency: hicolor-icon-theme for package: gtk2-2.24.31-1.el7.x86_64
--> Processing Dependency: libXcomposite.so.1()(64bit) for package: gtk2-2.24.31-1.el7.x86_64
--> Processing Dependency: libXcursor.so.1()(64bit) for package: gtk2-2.24.31-1.el7.x86_64
--> Processing Dependency: libXdamage.so.1()(64bit) for package: gtk2-2.24.31-1.el7.x86_64
--> Processing Dependency: libXfixes.so.3()(64bit) for package: gtk2-2.24.31-1.el7.x86_64
--> Processing Dependency: libXi.so.6()(64bit) for package: gtk2-2.24.31-1.el7.x86_64
--> Processing Dependency: libXinerama.so.1()(64bit) for package: gtk2-2.24.31-1.el7.x86_64
--> Processing Dependency: libXrandr.so.2()(64bit) for package: gtk2-2.24.31-1.el7.x86_64
---> Package lapack.x86_64 0:3.4.2-8.el7 will be installed
--> Processing Dependency: libblas.so.3()(64bit) for package: lapack-3.4.2-8.el7.x86_64
---> Package libICE.x86_64 0:1.0.9-9.el7 will be installed
---> Package libSM.x86_64 0:1.2.2-2.el7 will be installed
---> Package libX11-devel.x86_64 0:1.6.7-2.el7 will be installed
--> Processing Dependency: pkgconfig(xcb) >= 1.11.1 for package: libX11-devel-1.6.7-2.el7.x86_64
--> Processing Dependency: pkgconfig(kbproto) for package: libX11-devel-1.6.7-2.el7.x86_64
--> Processing Dependency: pkgconfig(xcb) for package: libX11-devel-1.6.7-2.el7.x86_64
--> Processing Dependency: pkgconfig(xproto) for package: libX11-devel-1.6.7-2.el7.x86_64
---> Package libXaw.x86_64 0:1.0.13-4.el7 will be installed
---> Package libXext.x86_64 0:1.3.3-3.el7 will be installed
---> Package libXmu.x86_64 0:1.1.2-2.el7 will be installed
---> Package libXpm-devel.x86_64 0:3.5.12-1.el7 will be installed
---> Package libXrender.x86_64 0:0.9.10-1.el7 will be installed
---> Package libXt.x86_64 0:1.1.5-3.el7 will be installed
---> Package libc-client.x86_64 0:2007f-16.el7 will be installed
---> Package libgfortran.x86_64 0:4.8.5-39.el7 will be installed
---> Package libgs.x86_64 0:9.25-2.el7_7.3 will be installed
--> Processing Dependency: lcms2 >= 2.6 for package: libgs-9.25-2.el7_7.3.x86_64
--> Processing Dependency: adobe-mappings-cmap for package: libgs-9.25-2.el7_7.3.x86_64
--> Processing Dependency: adobe-mappings-cmap-deprecated for package: libgs-9.25-2.el7_7.3.x86_64
--> Processing Dependency: adobe-mappings-pdf for package: libgs-9.25-2.el7_7.3.x86_64
--> Processing Dependency: liblcms2.so.2()(64bit) for package: libgs-9.25-2.el7_7.3.x86_64
--> Processing Dependency: libopenjp2.so.7()(64bit) for package: libgs-9.25-2.el7_7.3.x86_64
--> Processing Dependency: libpaper.so.1()(64bit) for package: libgs-9.25-2.el7_7.3.x86_64
---> Package libjpeg-turbo-devel.x86_64 0:1.2.90-8.el7 will be installed
---> Package libpng-devel.x86_64 2:1.5.13-7.el7_2 will be installed
---> Package libquadmath.x86_64 0:4.8.5-39.el7 will be installed
---> Package librsvg2.x86_64 0:2.40.20-1.el7 will be installed
---> Package m4.x86_64 0:1.4.16-10.el7 will be installed
---> Package neon.x86_64 0:0.30.0-4.el7 will be installed
--> Processing Dependency: libpakchois.so.0()(64bit) for package: neon-0.30.0-4.el7.x86_64
---> Package pango.x86_64 0:1.42.4-4.el7_7 will be installed
--> Processing Dependency: fribidi(x86-64) >= 1.0 for package: pango-1.42.4-4.el7_7.x86_64
--> Processing Dependency: harfbuzz(x86-64) >= 1.4.2 for package: pango-1.42.4-4.el7_7.x86_64
--> Processing Dependency: libXft(x86-64) >= 2.0.0 for package: pango-1.42.4-4.el7_7.x86_64
--> Processing Dependency: libthai(x86-64) >= 0.1.9 for package: pango-1.42.4-4.el7_7.x86_64
--> Processing Dependency: libthai.so.0(LIBTHAI_0.1)(64bit) for package: pango-1.42.4-4.el7_7.x86_64
--> Processing Dependency: libXft.so.2()(64bit) for package: pango-1.42.4-4.el7_7.x86_64
--> Processing Dependency: libfribidi.so.0()(64bit) for package: pango-1.42.4-4.el7_7.x86_64
--> Processing Dependency: libharfbuzz.so.0()(64bit) for package: pango-1.42.4-4.el7_7.x86_64
--> Processing Dependency: libthai.so.0()(64bit) for package: pango-1.42.4-4.el7_7.x86_64
---> Package perl-Crypt-DES.x86_64 0:2.05-20.el7 will be installed
---> Package perl-Digest-HMAC.noarch 0:1.03-5.el7 will be installed
---> Package perl-Digest-MD5.x86_64 0:2.52-3.el7 will be installed
--> Processing Dependency: perl(Digest::base) >= 1.00 for package: perl-Digest-MD5-2.52-3.el7.x86_64
---> Package perl-Digest-SHA.x86_64 1:5.85-4.el7 will be installed
---> Package perl-Digest-SHA1.x86_64 0:2.13-9.el7 will be installed
---> Package perl-Encode-Locale.noarch 0:1.03-5.el7 will be installed
---> Package perl-HTTP-Date.noarch 0:6.02-8.el7 will be installed
--> Processing Dependency: perl(Time::Zone) for package: perl-HTTP-Date-6.02-8.el7.noarch
---> Package perl-IO-HTML.noarch 0:1.00-2.el7 will be installed
---> Package perl-IO-Socket-SSL.noarch 0:1.94-7.el7 will be installed
--> Processing Dependency: perl(IO::Socket::IP) >= 0.20 for package: perl-IO-Socket-SSL-1.94-7.el7.noarch
--> Processing Dependency: perl(Net::SSLeay) >= 1.21 for package: perl-IO-Socket-SSL-1.94-7.el7.noarch
--> Processing Dependency: perl-Net-SSLeay >= 1.55-5 for package: perl-IO-Socket-SSL-1.94-7.el7.noarch
--> Processing Dependency: perl(Net::LibIDN) for package: perl-IO-Socket-SSL-1.94-7.el7.noarch
--> Processing Dependency: perl(Net::SSLeay) for package: perl-IO-Socket-SSL-1.94-7.el7.noarch
---> Package perl-LWP-MediaTypes.noarch 0:6.02-2.el7 will be installed
---> Package perl-Module-Implementation.noarch 0:0.06-6.el7 will be installed
--> Processing Dependency: perl(Module::Runtime) >= 0.012 for package: perl-Module-Implementation-0.06-6.el7.noarch
--> Processing Dependency: perl(Try::Tiny) for package: perl-Module-Implementation-0.06-6.el7.noarch
---> Package perl-Mozilla-CA.noarch 0:20130114-5.el7 will be installed
---> Package perl-Net-HTTP.noarch 0:6.06-2.el7 will be installed
---> Package perl-Parse-RecDescent.noarch 0:1.967009-5.el7 will be installed
---> Package perl-Thread-Queue.noarch 0:3.02-2.el7 will be installed
---> Package perl-URI.noarch 0:1.60-9.el7 will be installed
--> Processing Dependency: perl(Business::ISBN) for package: perl-URI-1.60-9.el7.noarch
---> Package perl-XML-NamespaceSupport.noarch 0:1.11-10.el7 will be installed
---> Package perl-XML-SAX.noarch 0:0.99-9.el7 will be installed
--> Processing Dependency: perl(XML::SAX::Base) for package: perl-XML-SAX-0.99-9.el7.noarch
--> Processing Dependency: perl(XML::SAX::Exception) for package: perl-XML-SAX-0.99-9.el7.noarch
---> Package perl-libwww-perl.noarch 0:6.05-2.el7 will be installed
--> Processing Dependency: perl(File::Listing) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTTP::Daemon) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTTP::Negotiate) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(WWW::RobotRules) >= 6 for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTML::Entities) for package: perl-libwww-perl-6.05-2.el7.noarch
--> Processing Dependency: perl(HTML::HeadParser) for package: perl-libwww-perl-6.05-2.el7.noarch
---> Package perl-local-lib.noarch 0:1.008010-4.el7 will be installed
---> Package php-process.x86_64 0:5.4.16-46.1.el7_7 will be installed
---> Package php72w-cli.x86_64 0:7.2.24-1.w7 will be installed
--> Processing Dependency: libargon2.so.0()(64bit) for package: php72w-cli-7.2.24-1.w7.x86_64
---> Package php72w-common.x86_64 0:7.2.24-1.w7 will be installed
---> Package php72w-pdo.x86_64 0:7.2.24-1.w7 will be installed
---> Package postgresql.x86_64 0:9.2.24-1.el7_5 will be installed
---> Package python-crypto.x86_64 0:2.6.1-1.el7ost will be installed
---> Package python-httplib2.noarch 0:0.9.1-2.el7aos will be installed
---> Package python-jinja2.noarch 0:2.7.2-4.el7 will be installed
--> Processing Dependency: python-babel >= 0.8 for package: python-jinja2-2.7.2-4.el7.noarch
--> Processing Dependency: python-markupsafe for package: python-jinja2-2.7.2-4.el7.noarch
---> Package python-nose.noarch 0:1.3.7-1.el7 will be installed
---> Package python-paramiko.noarch 0:2.1.1-9.el7 will be installed
--> Processing Dependency: python-cryptography for package: python-paramiko-2.1.1-9.el7.noarch
--> Processing Dependency: python2-pyasn1 for package: python-paramiko-2.1.1-9.el7.noarch
---> Package python-rpm-macros.noarch 0:3-32.el7 will be installed
--> Processing Dependency: python-srpm-macros for package: python-rpm-macros-3-32.el7.noarch
---> Package python2-rpm-macros.noarch 0:3-32.el7 will be installed
---> Package rpm-build.x86_64 0:4.11.3-40.el7 will be installed
--> Processing Dependency: patch >= 2.5 for package: rpm-build-4.11.3-40.el7.x86_64
--> Processing Dependency: system-rpm-config for package: rpm-build-4.11.3-40.el7.x86_64
---> Package sshpass.x86_64 0:1.05-5.el7aos will be installed
---> Package subversion-libs.x86_64 0:1.7.14-14.el7 will be installed
---> Package urw-base35-fonts.noarch 0:20170801-10.el7 will be installed
--> Processing Dependency: urw-base35-fonts-common = 20170801-10.el7 for package: urw-base35-fonts-20170801-10.el7.noarch
--> Processing Dependency: urw-base35-bookman-fonts for package: urw-base35-fonts-20170801-10.el7.noarch
--> Processing Dependency: urw-base35-c059-fonts for package: urw-base35-fonts-20170801-10.el7.noarch
--> Processing Dependency: urw-base35-d050000l-fonts for package: urw-base35-fonts-20170801-10.el7.noarch
--> Processing Dependency: urw-base35-gothic-fonts for package: urw-base35-fonts-20170801-10.el7.noarch
--> Processing Dependency: urw-base35-nimbus-mono-ps-fonts for package: urw-base35-fonts-20170801-10.el7.noarch
--> Processing Dependency: urw-base35-nimbus-roman-fonts for package: urw-base35-fonts-20170801-10.el7.noarch
--> Processing Dependency: urw-base35-nimbus-sans-fonts for package: urw-base35-fonts-20170801-10.el7.noarch
--> Processing Dependency: urw-base35-p052-fonts for package: urw-base35-fonts-20170801-10.el7.noarch
--> Processing Dependency: urw-base35-standard-symbols-ps-fonts for package: urw-base35-fonts-20170801-10.el7.noarch
--> Processing Dependency: urw-base35-z003-fonts for package: urw-base35-fonts-20170801-10.el7.noarch
---> Package adobe-mappings-cmap.noarch 0:20171205-3.el7 will be installed
---> Package adobe-mappings-cmap-deprecated.noarch 0:20171205-3.el7 will be installed
---> Package adobe-mappings-pdf.noarch 0:20180407-1.el7 will be installed
---> Package blas.x86_64 0:3.4.2-8.el7 will be installed
---> Package cyrus-sasl.x86_64 0:2.1.26-23.el7 will be installed
---> Package fribidi.x86_64 0:1.0.2-1.el7 will be installed
---> Package gtk-update-icon-cache.x86_64 0:3.22.30-3.el7 will be installed
---> Package harfbuzz.x86_64 0:1.7.5-2.el7 will be installed
--> Processing Dependency: libgraphite2.so.3()(64bit) for package: harfbuzz-1.7.5-2.el7.x86_64
---> Package hicolor-icon-theme.noarch 0:0.12-7.el7 will be installed
---> Package lcms2.x86_64 0:2.6-3.el7 will be installed
---> Package libXcomposite.x86_64 0:0.4.4-4.1.el7 will be installed
---> Package libXcursor.x86_64 0:1.1.15-1.el7 will be installed
---> Package libXdamage.x86_64 0:1.1.4-4.1.el7 will be installed
---> Package libXfixes.x86_64 0:5.0.3-1.el7 will be installed
---> Package libXft.x86_64 0:2.3.2-2.el7 will be installed
---> Package libXi.x86_64 0:1.7.9-1.el7 will be installed
---> Package libXinerama.x86_64 0:1.1.3-2.1.el7 will be installed
---> Package libXrandr.x86_64 0:1.5.1-2.el7 will be installed
---> Package libglvnd-egl.x86_64 1:1.0.1-0.8.git5baa1e5.el7 will be installed
--> Processing Dependency: libglvnd(x86-64) = 1:1.0.1-0.8.git5baa1e5.el7 for package: 1:libglvnd-egl-1.0.1-0.8.git5baa1e5.el7.x86_64
--> Processing Dependency: mesa-libEGL(x86-64) >= 13.0.4-1 for package: 1:libglvnd-egl-1.0.1-0.8.git5baa1e5.el7.x86_64
--> Processing Dependency: libGLdispatch.so.0()(64bit) for package: 1:libglvnd-egl-1.0.1-0.8.git5baa1e5.el7.x86_64
---> Package libglvnd-glx.x86_64 1:1.0.1-0.8.git5baa1e5.el7 will be installed
--> Processing Dependency: mesa-libGL(x86-64) >= 13.0.4-1 for package: 1:libglvnd-glx-1.0.1-0.8.git5baa1e5.el7.x86_64
---> Package libpaper.x86_64 0:1.1.24-8.el7 will be installed
---> Package libthai.x86_64 0:0.1.14-9.el7 will be installed
---> Package libuuid-devel.x86_64 0:2.23.2-61.el7_7.1 will be installed
--> Processing Dependency: libuuid = 2.23.2-61.el7_7.1 for package: libuuid-devel-2.23.2-61.el7_7.1.x86_64
---> Package libxcb-devel.x86_64 0:1.13-1.el7 will be installed
--> Processing Dependency: pkgconfig(xau) >= 0.99.2 for package: libxcb-devel-1.13-1.el7.x86_64
---> Package openjpeg2.x86_64 0:2.3.1-1.el7 will be installed
---> Package pakchois.x86_64 0:0.4-10.el7 will be installed
---> Package patch.x86_64 0:2.7.1-12.el7_7 will be installed
---> Package perl-Business-ISBN.noarch 0:2.06-2.el7 will be installed
--> Processing Dependency: perl(Business::ISBN::Data) >= 20120719.001 for package: perl-Business-ISBN-2.06-2.el7.noarch
---> Package perl-Digest.noarch 0:1.17-245.el7 will be installed
---> Package perl-File-Listing.noarch 0:6.04-7.el7 will be installed
---> Package perl-HTML-Parser.x86_64 0:3.71-4.el7 will be installed
--> Processing Dependency: perl(HTML::Tagset) >= 3 for package: perl-HTML-Parser-3.71-4.el7.x86_64
---> Package perl-HTTP-Daemon.noarch 0:6.01-8.el7 will be installed
---> Package perl-HTTP-Negotiate.noarch 0:6.01-5.el7 will be installed
---> Package perl-IO-Socket-IP.noarch 0:0.21-5.el7 will be installed
---> Package perl-Module-Runtime.noarch 0:0.013-4.el7 will be installed
---> Package perl-Net-LibIDN.x86_64 0:0.12-15.el7 will be installed
---> Package perl-Net-SSLeay.x86_64 0:1.55-6.el7 will be installed
---> Package perl-TimeDate.noarch 1:2.30-2.el7 will be installed
---> Package perl-Try-Tiny.noarch 0:0.12-2.el7 will be installed
---> Package perl-WWW-RobotRules.noarch 0:6.02-5.el7 will be installed
---> Package perl-XML-SAX-Base.noarch 0:1.08-7.el7 will be installed
---> Package python-babel.noarch 0:1.3-6.el7ost will be installed
--> Processing Dependency: pytz for package: python-babel-1.3-6.el7ost.noarch
---> Package python-markupsafe.x86_64 0:0.11-10.el7 will be installed
---> Package python-srpm-macros.noarch 0:3-32.el7 will be installed
---> Package python2-cryptography.x86_64 0:1.7.2-2.el7 will be installed
--> Processing Dependency: python-cffi >= 1.4.1 for package: python2-cryptography-1.7.2-2.el7.x86_64
--> Processing Dependency: python-idna >= 2.0 for package: python2-cryptography-1.7.2-2.el7.x86_64
--> Processing Dependency: python-enum34 for package: python2-cryptography-1.7.2-2.el7.x86_64
---> Package python2-pyasn1.noarch 0:0.1.9-7.el7 will be installed
---> Package redhat-rpm-config.noarch 0:9.1.0-88.el7 will be installed
--> Processing Dependency: dwz >= 0.4 for package: redhat-rpm-config-9.1.0-88.el7.noarch
--> Processing Dependency: perl-srpm-macros for package: redhat-rpm-config-9.1.0-88.el7.noarch
---> Package urw-base35-bookman-fonts.noarch 0:20170801-10.el7 will be installed
--> Processing Dependency: xorg-x11-font-utils for package: urw-base35-bookman-fonts-20170801-10.el7.noarch
--> Processing Dependency: xorg-x11-server-utils for package: urw-base35-bookman-fonts-20170801-10.el7.noarch
---> Package urw-base35-c059-fonts.noarch 0:20170801-10.el7 will be installed
---> Package urw-base35-d050000l-fonts.noarch 0:20170801-10.el7 will be installed
---> Package urw-base35-fonts-common.noarch 0:20170801-10.el7 will be installed
---> Package urw-base35-gothic-fonts.noarch 0:20170801-10.el7 will be installed
---> Package urw-base35-nimbus-mono-ps-fonts.noarch 0:20170801-10.el7 will be installed
---> Package urw-base35-nimbus-roman-fonts.noarch 0:20170801-10.el7 will be installed
---> Package urw-base35-nimbus-sans-fonts.noarch 0:20170801-10.el7 will be installed
---> Package urw-base35-p052-fonts.noarch 0:20170801-10.el7 will be installed
---> Package urw-base35-standard-symbols-ps-fonts.noarch 0:20170801-10.el7 will be installed
---> Package urw-base35-z003-fonts.noarch 0:20170801-10.el7 will be installed
---> Package xorg-x11-proto-devel.noarch 0:2018.4-1.el7 will be installed
---> Package dwz.x86_64 0:0.11-3.el7 will be installed
---> Package graphite2.x86_64 0:1.3.10-1.el7_3 will be installed
---> Package libXau-devel.x86_64 0:1.0.8-2.1.el7 will be installed
---> Package libglvnd.x86_64 1:1.0.1-0.8.git5baa1e5.el7 will be installed
---> Package libuuid.x86_64 0:2.23.2-61.el7 will be updated
--> Processing Dependency: libuuid = 2.23.2-61.el7 for package: util-linux-2.23.2-61.el7.x86_64
--> Processing Dependency: libuuid = 2.23.2-61.el7 for package: libblkid-2.23.2-61.el7.x86_64
--> Processing Dependency: libuuid = 2.23.2-61.el7 for package: libmount-2.23.2-61.el7.x86_64
---> Package libuuid.x86_64 0:2.23.2-61.el7_7.1 will be an update
---> Package mesa-libEGL.x86_64 0:18.3.4-5.el7 will be installed
--> Processing Dependency: mesa-libgbm = 18.3.4-5.el7 for package: mesa-libEGL-18.3.4-5.el7.x86_64
--> Processing Dependency: libgbm.so.1()(64bit) for package: mesa-libEGL-18.3.4-5.el7.x86_64
--> Processing Dependency: libglapi.so.0()(64bit) for package: mesa-libEGL-18.3.4-5.el7.x86_64
--> Processing Dependency: libwayland-client.so.0()(64bit) for package: mesa-libEGL-18.3.4-5.el7.x86_64
--> Processing Dependency: libwayland-server.so.0()(64bit) for package: mesa-libEGL-18.3.4-5.el7.x86_64
--> Processing Dependency: libxshmfence.so.1()(64bit) for package: mesa-libEGL-18.3.4-5.el7.x86_64
---> Package mesa-libGL.x86_64 0:18.3.4-5.el7 will be installed
--> Processing Dependency: libXxf86vm.so.1()(64bit) for package: mesa-libGL-18.3.4-5.el7.x86_64
---> Package perl-Business-ISBN-Data.noarch 0:20120719.001-2.el7 will be installed
---> Package perl-HTML-Tagset.noarch 0:3.20-15.el7 will be installed
---> Package perl-srpm-macros.noarch 0:1-8.el7 will be installed
---> Package python-cffi.x86_64 0:1.6.0-5.el7 will be installed
--> Processing Dependency: python-pycparser for package: python-cffi-1.6.0-5.el7.x86_64
---> Package python-enum34.noarch 0:1.0.4-1.el7 will be installed
---> Package python-idna.noarch 0:2.4-1.el7 will be installed
---> Package pytz.noarch 0:2016.10-2.el7 will be installed
---> Package xorg-x11-font-utils.x86_64 1:7.5-21.el7 will be installed
--> Processing Dependency: libfontenc.so.1()(64bit) for package: 1:xorg-x11-font-utils-7.5-21.el7.x86_64
---> Package xorg-x11-server-utils.x86_64 0:7.7-20.el7 will be installed
--> Processing Dependency: libXxf86misc.so.1()(64bit) for package: xorg-x11-server-utils-7.7-20.el7.x86_64
---> Package libXxf86misc.x86_64 0:1.0.3-7.1.el7 will be installed
---> Package libXxf86vm.x86_64 0:1.1.4-1.el7 will be installed
---> Package libblkid.x86_64 0:2.23.2-61.el7 will be updated
---> Package libblkid.x86_64 0:2.23.2-61.el7_7.1 will be an update
---> Package libfontenc.x86_64 0:1.1.3-3.el7 will be installed
---> Package libmount.x86_64 0:2.23.2-61.el7 will be updated
---> Package libmount.x86_64 0:2.23.2-61.el7_7.1 will be an update
---> Package libwayland-client.x86_64 0:1.15.0-1.el7 will be installed
---> Package libwayland-server.x86_64 0:1.15.0-1.el7 will be installed
---> Package libxshmfence.x86_64 0:1.2-1.el7 will be installed
---> Package mesa-libgbm.x86_64 0:18.3.4-5.el7 will be installed
---> Package mesa-libglapi.x86_64 0:18.3.4-5.el7 will be installed
---> Package python-pycparser.noarch 0:2.14-1.el7 will be installed
--> Processing Dependency: python-ply for package: python-pycparser-2.14-1.el7.noarch
---> Package util-linux.x86_64 0:2.23.2-61.el7 will be updated
---> Package util-linux.x86_64 0:2.23.2-61.el7_7.1 will be an update
--> Processing Dependency: libsmartcols = 2.23.2-61.el7_7.1 for package: util-linux-2.23.2-61.el7_7.1.x86_64
---> Package libsmartcols.x86_64 0:2.23.2-61.el7 will be updated
---> Package libsmartcols.x86_64 0:2.23.2-61.el7_7.1 will be an update
---> Package python-ply.noarch 0:3.4-11.el7 will be installed
--> Processing Conflict: php72w-common-7.2.24-1.w7.x86_64 conflicts php-common < 7.2
--> Processing Conflict: nagiosxi-deps-el7-5.6.8-1.noarch conflicts nagios-nrpe
No package matched to upgrade: nagiosxi-deps-el7
--> Processing Conflict: nagiosxi-deps-el7-5.6.8-1.noarch conflicts nrpe
Requires: snmptt
Dependency resolving failed due to missing dependencies.
Some repositories on your system are disabled, but yum can enable them
and search for missing dependencies. This will require downloading
metadata for disabled repositories and may take some time and traffic.
https://cdn.redhat.com/content/els/rhel ... repomd.xml: [Errno 14] HTTPS Error 404 - Not Found
Trying other mirror.
To address this issue please refer to the below knowledge base article
https://access.redhat.com/articles/1320623
If above article doesn't help to resolve this issue please open a ticket with Red Hat Support.
https://cdn.redhat.com/content/eus/rhel ... repomd.xml: [Errno 14] HTTPS Error 404 - Not Found
https://cdn.redhat.com/content/dist/rhe ... repomd.xml: [Errno 14] HTTPS Error 403 - Forbidden
https://access.redhat.com/solutions/69319
https://cdn.redhat.com/content/e4s/rhel ... repomd.xml: [Errno 14] HTTPS Error 404 - Not Found
Requires: snmptt
RESULT=1
INSTALLATION ERROR!
in your communications with Nagios XI technical support.
The script that failed was: './1-prereqs'
Huge problems while installing Nagios XI
Re: Huge problems while installing Nagios XI
Looks like you have added webtatic repositories
From our installation documentation:
If you have a need to upgrade php versions, you need to use a repository that doesn't change the php package names, such as the instructions found here, preferably AFTER the installation completes successfully.
https://support.nagios.com/kb/article/n ... 7-860.html
https://assets.nagios.com/downloads/nag ... -Linux.pdfImportant: Nagios Enterprises highly recommends and will only support installing Nagios XI on a newly installed, "clean" system (a bare minimal install with nothing else installed or configured).
