Question with check_mem
Leoncia
I have a problem with the check_mem. When I monitor a service memory with this check, it checks the virtual memory plus the physical memory and I just want to know the Virutal memory; is there a type of argument for this check to achieve this?
I have Nagios XI and I am using check_nrpe and later in the argument I call the check_memory
Re: Question with check_mem
Hello and welcome to the forum!
Are you using a windows system or Linux system? If Linux, can you attach the plugin you are using?
Leoncia
Hi!
Thank you for the welcoming
Well, I am using a Linux system and the plugin I am using is check_nt and the command line that I use is this one:
$USER1$/check_nt -H $HOSTADDRESS$ -s "$ARG1$" -p 12489 -v $ARG2$ $ARG3$ $ARG4$
Later in the argument 2 I am using "MEMUSE"
To remove virtual memory you are going to want to use check_nrpe, see an example here
https://support.nagios.com/kb/article.php?id=774
Leoncia
I want to see just the virtual memory. For what I see in the page, NCPA can do it, isn't?
Yes, but NSClient can too, listed on that page in this section:Leoncia wrote:I want to see just the virtual memory. For what I see in the page, NCPA can do it, isn't?
NSClient++ via check_nrpe
To only check the physical memory the type= argument can be used:
Command:Output:Code: Select all
./check_nrpe -H 10.25.14.10 -c check_memory -a type=physical 'warn=free<20%' 'crit=free<10%'Code: Select all
OK: physical = 2.101GB|'physical'=3.89902GB;1.19991;0.59995;0;5.99956 'physical %'=64%;19;9;0;100
Leoncia
I did a new command and I wrote the next line:
$USER1$/check_nrpe -H $HOSTADDRESS$ -c check_memory -a type=virtual MaxWarn=$ARG1$ MaxCrit=$ARG2$
And it says:
CHECK_NRPE: Invalid packet type received from server.
I try it too with the type=physical and says the same thing.
I have correct connetion to the port 5666:
telnet 10.16.70.200 5666
Trying 10.16.70.200...
Connected to 10.16.70.200.
And it says:
Try this
where
$ARG1$ = 80
$ARG2$ = 90
$USER1$/check_nrpe -H $HOSTADDRESS$ -c check_memory -a type=physical 'warn=used>$ARG1$%' 'crit=used>$ARG2$%'$ARG1$ = 80
$ARG2$ = 90
Leoncia
It works perfectly in the service that I was testing:
OK: |'virtual'=0.00011TB;102.4;115.2;0;128 'virtual %'=0%;79;89;0;100
But, I try to copy it to other hosts and reponds the next:
Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
I think it's because of the nsclient.ini, that in the first one there is something that in others is not
in the section
You need
then you will need to restart nsclient++
[/settings/NRPE/server]Code: Select all
allow nasty characters = 1
allow arguments = 1
