All was well until now, but I've a frustrating issue today. I hope you can help.
I wanted to set up a test host (my own laptop) to check out passive monitoring / unconfigured objects.
I installed NCPA 2.2 onto my Windows 10 Enterprise machine, then set it up as you can see in the attachment. Very basic setup, nothing really fancy.
I wanted it to check in to my Nagios XI server (installed on CentOS 7) every N seconds, and send some data so I can see how's that working.
What happens is that nothing appears on the Unconfigured list, and in the log, there're copies of HTML source, apparently from my Nagios server, that indicates internal server errors.
Something like this (excerpt from the NCPA log that's also attached):
2019-12-03 13:07:19,506:ERROR:ncpa_windows:Stdout or returncode was None, cannot return meaningfully.
Traceback (most recent call last):
File "C:\ncpa\agent\ncpa_windows.py", line 247, in run_all_handlers
File "C:\ncpa\agent\passive\nrdp.py", line 115, in run
File "C:\ncpa\agent\passive\nrdp.py", line 97, in get_xml_of_checkresults
File "C:\ncpa\agent\passive\nrdp.py", line 56, in make_xml
File "C:\ncpa\agent\passive\ncpacheck.py", line 84, in run
ValueError: Stdout or returncode was None, cannot return meaningfully.
2019-12-03 13:07:20,617:ERROR:app:Exception on /api/processes/ [GET]
File "C:\Python27\lib\site-packages\flask\app.py", line 1817, in wsgi_app
File "C:\Python27\lib\site-packages\flask\app.py", line 1477, in full_dispatch_request
File "C:\Python27\lib\site-packages\flask\app.py", line 1381, in handle_user_exception
File "C:\Python27\lib\site-packages\flask\app.py", line 1475, in full_dispatch_request
File "C:\Python27\lib\site-packages\flask\app.py", line 1461, in dispatch_request
File "C:\ncpa\agent\listener\server.py", line 185, in token_auth_decoration
File "C:\ncpa\agent\listener\server.py", line 946, in api
File "C:\ncpa\agent\listener\processes.py", line 420, in run_check
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc1 in position 1261: ordinal not in range(128)
2019-12-03 13:07:20,618:ERROR:ncpacheck:Error with JSON: No JSON object could be decoded. JSON was: <!DOCTYPE html>
<html lang='en'>
<head>
<title>Page Not Found · NCPA</title>
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<meta name="description" content="NCPA Web Interface">
<meta name="author" content="Nagios Enterprises, LLC">
<link rel="shortcut icon" type="image/png" href="/static/img/ncpa.png" />
<link rel="icon" type="image/png" href="/static/img/ncpa.png" />
<link rel='stylesheet' href='/static/css/bootstrap.min.css'>
<link rel='stylesheet' href='/static/css/font-awesome.min.css'>
<link rel='stylesheet' href='/static/css/ncpa.css'>
<script src='/static/js/jquery.2.2.4.min.js'></script>
<script src='/static/js/bootstrap.min.js'></script>
<script src='/static/js/d3.v4.min.js'></script>
<script src='/static/js/main.js'></script>
</head>
<body style="padding-top: 50px;">
<nav class="navbar navbar-inverse navbar-default navbar-fixed-top">
<div class="container-fluid">
<div class="navbar-header">
<button type="button" class="navbar-toggle collapsed" data-toggle="collapse" data-target="#navbar-collapse-left">
<span class="sr-only">Toggle navigation</span>
<span class="icon-bar"></span>
</button>
<a class="navbar-brand" href="/gui/">NCPA</a>
</div>
<div class="collapse navbar-collapse" id="navbar-collapse-left">
<ul class="nav navbar-nav">
</ul>
</div>
</div>
</nav>
<div id="main-content-container">
<div style="text-align: center;">
<h1 style="font-size: 12rem; padding: 8rem 0 3rem 0; color: #CCC;">500</h1>
<p style="font-size: 1.8rem;">There was a internal server error. Please contact your system administrator.</p>
</div>
</div>
</body>
</html>
2019-12-03 13:07:20,618:ERROR:ncpa_windows:Stdout or returncode was None, cannot return meaningfully.
2019-12-03 13:07:21,729:ERROR:app:Exception on /api/processes/ [GET]
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc1 in position 1259: ordinal not in range(128)
2019-12-03 13:07:21,730:ERROR:ncpacheck:Error with JSON: No JSON object could be decoded. JSON was: <!DOCTYPE html>
<html lang='en'>
<head>
</head>
</button>
</div>
</ul>
</div>
</div>
</nav>
</div>
</div>
</body>
</html>What could be going on, where do I look?
Thanks in advance!
