When we execute the following check command we are getting following error.
[root@nagios libexec]# ./check_nrpe -H host1 -p 5666 -c CheckEventLog -a filter=new file=system MaxWarn=1 MaxCrit=1 filter-generated=\>5m filter+eventID=="10004" filter+eventType==error filter+eventSource==DCOM filter=in filter=all truncate=30
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
[root@nagios]# ./check_nrpe -H host1 -p 5666
I (0.3.5.1 2008-09-24) seem to be doing fine...
I truncated the command and tried.
[root@nagios]# ./check_nrpe -H host1 -p 5666 -c CheckEventLog -a filter=new file=system
What is wrong in the check command.
Please help me.
Regards,
Pratapa
Error while executing check command
Re: Error while executing check command
The NSClient++ agent you are running is very old and I recommend upgrading to a newer version if possible.
The error is caused be a missing option in the NSClient++ ini file so can you go to the following folder
Get the nsc.ini file and upload it here so we can view it?
C:\Program Files\NSClient++Be sure to check out our Knowledgebase for helpful articles and solutions!
I replied to the user asking for details.
I will get back to you once I get the details from the user.
Please find the details
NSClient++ version is NSClientpp (Nagios) 0.3.5.2 2008-09-24 w32.
Uploaded nsc.ini file
- NSC.rar
- nsc.ini file
- (4.57 KiB) Downloaded 403 times
That agent is 11 years old so I don't know if what I suggest will work.
Edit the nsc.ini file and under the [NRPE] section, change the following from
to
Save the change and restart NSClient++ and test the command.
;allow_arguments=0
;allow_nasty_meta_chars=0Code: Select all
allow_arguments=1
allow_nasty_meta_chars=1Be sure to check out our Knowledgebase for helpful articles and solutions!
