Hi.
I'm trying to monitor a specfic process / service on Windows and the CPU load for that service.
Any tip?
Using NagiosXI - NSClient and NCPA, can use other plugins aswell.
Windows, service and CPU load.
Re: Windows, service and CPU load.
Absolutely you can do this with NCPA. If you have NCPA installed on your Windows machine already, you can just use the NCPA wizard. During Step 2 of the NCPA wizard, you will be able to set your warning and critical thresholds for CPU utilization. You will also be able to select services that you want to monitor.
Perfect
I had forgotten that option.
Thank you.
Thank you.
You're welcome! I will go ahead and close this thread, but definitely open a new one if you run into any trouble.
