In Nagios GUI getting Critical errors
dheerushops
Post by dheerushops »
In Nagios server GUI. Getting below error for Remote servers. For alerts CPU, FTP,SSH.
No output on stdout) stderr: execvp(/usr/local/nagios/libexec/check_nrpe, ...) failed. errno is 2: No such file or directory
benjaminsmith
Re: In Nagios GUI getting Critical errors
Post by benjaminsmith »
Hello @dheerushops,
The plugin is missing for some reason, perhaps in the wrong path. What is the output of the following commands?
Verify the plugin is in the right location:
find / -name check_nrpe
Check the permissions:
ls -l /usr/local/nagios/libexec/check_nrpe
dheerushops
[root@nagiosserver ~]# find / -name check_nrpe
/tmp/nrpe-2.15/nrpe-2.15/src/check_nrpe
[root@nagiosserver ~]# ls -l /usr/local/nagios/libexec/check_nrpe
-rwxr-xr-x 1 root root 76785 Dec 6 08:52 /usr/local/nagios/libexec/check_nrpe
dheerushops
Given output is from Nagios monitoring server
dheerushops
Below output is from nagios client host.
[root@nagioshost~]# find / -name check_nrpe
/root/nagios/nrpe-2.15/src/check_nrpe
[root@nagioshost~]#
[root@nagioshost~]# ls -l /usr/local/nagios/libexec/check_nrpe
-rwxrwxr-x 1 nagios nagios 76777 Dec 3 13:21 /usr/local/nagios/libexec/check_nrpe
[root@nagioshost~]#
benjaminsmith
This looks like the problem. The permissions on check_nrpe are set to root on the Nagios server.
Run the following to corret and try once more.
chmod 775 /usr/local/nagios/libexec/check_nrpe
chown nagios:nagios /usr/local/nagios/libexec/check_nrpe
dheerushops
For Nagios host getting below errors in Nagios monitoring tool.
nagioshost
FTP Monitoring
CRITICAL 12-11-2019 08:45:13 7d 19h 43m 3s 3/3 NRPE: Command 'check_ftp' not defined
SSH Monitoring
CRITICAL 12-11-2019 08:46:28 7d 19h 41m 48s 3/3 NRPE: Command 'check_ssh' not defined
Total Processes
CRITICAL 12-11-2019 08:47:43 7d 19h 40m 33s 3/3 PROCS CRITICAL: 263 processes
It seems like the 'check_ftp' and 'check_ssh' commands are not defined in nrpe.cfg on the client machine... You will have to define them on remote box, and restart the nrpe service. Then, you can run your checks again from the command line on the nagios server to see if the issue has been resolved.
dheerushops
I have added entries in file " /usr/local/nagios/etc/services.cfg"
host_name nagioshost
service_description SSH Monitoring
check_command check_nrpe!check_ssh
service_description FTP Monitoring
check_command check_nrpe!check_ftp
Well, you defined you services on the nagios server, but you haven't defined you commands on the remote machine (the host that you are monitoring)...
Here's an example of a command definition that can be placed in your nrpe.cfg file on the client machine:
command[check_ftp]=/usr/local/nagios/libexec/check_ftp -H $ARG1$ -p $ARG2$
After saving the file, and restarting nrpe on the remote box, so that changes can take effect:
service nrpe restart
you can test your check by running the following command on the nagios server:
/usr/local/nagios/libexec/check_nrpe -H <client ip> -c check_ftp -a '<ip address of your FTP server>' '<port number>'
In this example, you are passing 2 arguments - FTP server's IP address and a port number.
Example:
/usr/local/nagios/libexec/check_nrpe -H 192.168.x.x -c check_ftp -a '192.168.y.y' '21'
FTP OK - 0.002 second response time on 192.168.y.y port 21 [220 (vsFTPd 2.2.2)]|time=0.001744s;;;0.000000;10.000000
Bottom line: when you use check_nrpe you pass your command with the "-c" flag. The command is defined on the remote box (host that you are monitoring). You pass arguments if needed, using the "-a" flag.
./check_nrpe -H <client ip> -c <command> -a <arguments>
Does this make sense?
