access the NAgiosXI from web console its throwing the error
vinish098
Post by vinish098 »
We started testing the connectivity ofoffload DB and Nagios. The Nagios server was able to connect to all 3 offloading DB's.
But when we are trying to access the NAgiosXI from web console its throwing the error connection failed: Can't connect to local MySQL server through socket '/var/mysql/mysql.sock' (22).
while we are stop the mariadb services it will throws that error.
and these are configuration files: vi /usr/local/nagios/etc/ndo2db.cfg
vi /usr/local/nagiosxi/html/config.inc.php
and kindly please check the below attachments. and please do the needful help.
Regards
Sai kiran
Re: access the NAgiosXI from web console its throwing the er
Did you follow ALL OF THE STEPS, outlined in the document below?
https://assets.nagios.com/downloads/nag ... Server.pdf
It seems like that in the configs, your database server is still set as "localhost"... You should have:
"dbserver" => '<IP_OF_MYSQL_OR_MARIADB_SERVER>'
Please revisit our official document on the topic, and make sure you followed all steps.
