Nagios has not received an update from host1
Pratapa
Post by Pratapa »
User is complaining that he is receiving so many Warning alerts.
Message is showing as follows in Nagios:
Nagios has not received an update from host1 for at least 10 minutes.
They are all passive checks.
How can this be resolved?
Please help me.
Pratapa
Re: Nagios has not received an update from host1
Post by Pratapa »
I logged into the client machine and executed the below command
/usr/local/nagios/bin/send_nsca -H nagiosserver -c /usr/local/nagios/etc/send_nsca.cfg -p 5667
Error: Timeout after 10 seconds
Client machine is AIX server.
Pratapa
Post by Pratapa »
From Nagios server I executed the following command.
[root@nagiosserver]# telnet clientmachine 5667
Trying xx.xx.xx.xx...
telnet: connect to address xx.xx.xx.xx: Connection refused
Have you added the client's IP address to the "only_from" line in the "/etc/xinetd.d/nsca" file on your Nagios server? By default, NSCA can only allows connections from the Nagios server itself. In order to allow remote hosts and applications to send passive results to Nagios you will need to configure access. After adding the remote machine's IP address to "/etc/xinetd.d/nsca", you will need to restart xinetd, so that changes can take effect:
service xinetd restart
Also, have you checked you firewall rules? Is TCP port 5667 open?
Pratapa
Post by Pratapa »
There are no files under /etc/xinetd.d
[root@nagiosserver xinetd.d]# pwd
/etc/xinetd.d
[root@nagiosserver xinetd.d]# ls
[root@nagiosserver]# ps -ef|grep nsca
nagios 16542 1 0 Sep06 ? 00:11:52 /opt/nagios/bin/nsca --single -c /opt/nagios/etc/nsca.cfg
root 87413 75750 0 17:19 pts/2 00:00:00 grep --color=auto nsca
[root@nagiosserver xinetd.d]# /bin/systemctl status xinetd.service
Unit xinetd.service could not be found.
Port 5667 is open on Nagios server.
[root@nagiosserver ]# netstat -an|grep 5667
tcp 129 0 0.0.0.0:5667 0.0.0.0:* LISTEN
output truncated....
[root@nagiosserver ]# netstat -an|grep 5667|wc -l
127
There are so many processes listening on port 5667. Some of them are in CLOSE_WAIT and some are in SYN_RECV
Pratapa
Post by Pratapa »
[root@nagiosserver]# lsof -i|grep 5667
nsca 16542 nagios 4u IPv4 13404327 0t0 TCP *:5667 (LISTEN)
nsca 16542 nagios 5u IPv4 1509107706 0t0 TCP nagiosserver:5667->server1.be.corp:51587 (CLOSE_WAIT)
Pratapa
Post by Pratapa »
This issue is resolved after killing the process having PID 16542.
Restarted nsca service.
I am glad your issue has been resolved! I am closing this topic now. If you have any further questions/issues, please start a new thread.
