MKLivestatus No UNIX socket existing
TechnicallyTrue
Post by TechnicallyTrue »
I'm currently in the process of setting up NagVis, and one of the prerequisites is that mk-livestatus be up and running on your Nagios server. This is proving difficult.
The website for mk-livestatus doesn't have much in the way of installation instructions, so I went off of this guide here:
https://stackoverflow.com/questions/161 ... -on-nagios
I made the small adjustment that /usr/lib/nagios/mk-livestatus is now /usr/lib64/nagios/mk-livestatus.
Unfortunately, after getting to the end, I encounter a problem: running the test command
echo 'GET hosts' | unixcat /usr/lib64/nagios/mk-livestatus/live
yields the error message
No UNIX socket /usr/lib64/nagios/mk-livestatus/live existing
I've tried installing more recent versions of mk-livestatus, but every other version number I enter into the wget command just comes back with ERROR 404: Not Found.
I'm running Nagios 4.3.4 on a CentOS 7 server. Any advice would be greatly appreciated.
Thank you very much.
Re: MKLivestatus No UNIX socket existing
Post by Box293 »
It's hard to provide any support for this as it is not a product made by Nagios and thus we do not have guides on how to set this up or troubleshoot it. While Nagios products do leverage many open-source projects, we do not utilise this project in our enterprise products and hence we do not have much knowledge on it.
We suggest contacting the owner of the project for support.
TechnicallyTrue
In the end, I changed /usr/lib64/nagios/mk-livestatus back to /usr/lib/nagios/mk-livestatus. I had to make the directories all the way down from /usr/lib and chown them, and there are some configuration options in NagVis that need to change, but it works now.
TechnicallyTrue wrote:In the end, I changed /usr/lib64/nagios/mk-livestatus back to /usr/lib/nagios/mk-livestatus. I had to make the directories all the way down from /usr/lib and chown them, and there are some configuration options in NagVis that need to change, but it works now.
Great!
Locking thread
