Nagios XI Daemons critical alert ...
xpertech
Post by xpertech »
There're a lot "Critical :Error: Could not parse XML from http://10.36.5.199/nagiosxi/ (<?xml version="1.0" encoding="utf-8"?>"
Monitor the service with this command: (Advanced users only)
check_xi_nagiosxiserver!--address=10.36.5.199 --url=http://10.36.5.199/nagiosxi/ --username=nagiosadmin --ticket="e2h5n9nf" --mode=daemons!!!!!!!
What could be the problem?
benjaminsmith
Re: Nagios XI Daemons critical alert ...
Post by benjaminsmith »
Hello @Xpertech,
The 'ticket' used in the comand has been deprecated. Try running the new version of the command from the shell, and let me know if you're getting the correct output. You'll need to add the api key to the command string. If you click on your username in the upper right, you can retrieve your API key.
Command:
 /usr/bin/php /usr/local/nagios/libexec/check_nagiosxiserver.php --address=$HOSTADDRESS$ --url='https://<ip address>/nagiosxi/' --apikey='your-api-key' --mode=daemons
If this working, update the arguments for the service check for Nagios XI Daemons in the CCM.
