objects/statehistory API data
meganwilliford
Post by meganwilliford »
I am noticing in the objects/statehistory API some data that seems like should be in there is not. It looks like only the past 24 hrs of data appears in the API, is that correct? And what isn't appearing is if a service state has been in a critical status for > 24 hrs but the last check was 5 minutes ago and is still critical, that last state does not appear in the API. Is that the right behavior?
Example of what isn't reporting to the objects/statehistory API:
Service status for: ntpd
Service State: Critical
Duration: 1d 23h 22m 3s
Service Stability: Unchanging (stable)
Last Check: 2019-12-11 12:59:41
Next Check: 2019-12-11 13:02:01
Re: objects/statehistory API data
Can you show us your actual API call and the output of it? Are you passing a "starttime" or you are using the "default" timestamp (Default: -24 hours)?
meganwilliford
We have the default -24hr. I think I get it now... so only state changes get reported and if it hasn't changed within 24 hrs then there won't be anything new in the API?
Yes, without passing a starttime this REST API call would only show the last 24 hours of state changes. Let us know if you have any further questions. Thanks!
meganwilliford
Thanks! You can lock this post.
You are welcome! Locking it.
