Nagios log file is not rotating in daily basis
breddydu
Post by breddydu »
We can see that the nagios.log is not rotationg dailuy basis, could you please help us.
Nagios version : 4.1.1
Please find the nagios.cfg log retention details .
# LOG ROTATION METHOD
# This is the log rotation method that Nagios should use to rotate
# the main log file. Values are as follows..
# n = None - don't rotate the log
# h = Hourly rotation (top of the hour)
# d = Daily rotation (midnight every day)
# w = Weekly rotation (midnight on Saturday evening)
# m = Monthly rotation (midnight last day of month)
log_rotation_method=d
# LOG ARCHIVE PATH
#log_archive_path=/var/log/nagios/archives
We could see two below process running continuously .
/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg.
22223 nagios 20 0 32000 8992 1168 S 1.3 0.2 0:07.44 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
1844 nagios 20 0 32000 7882 1168 S 2.3 0.2 200:0.44 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
Please help us in resolving this, let us know for more info .
Re: Nagios log file is not rotating in daily basis
Run the following command and show the output:
ls -lad /usr/local /usr/local/nagios /usr/local/nagios/var /usr/local/nagios/var/archives/
Also, post the entire nagios.cfg file on the forum.
breddydu
Post by breddydu »
Hello ,
Thanks for your reply.
Below is the output of the command you have given .
[root@HT-Nagios-Tools1 var]# ls -lad /usr/local /usr/local/nagios /usr/local/nagios/var /usr/local/nagios/var/archives/
drwxr-xr-x. 15 root root 4096 Dec 8 2016 /usr/local
drwxr-xr-x. 12 root root 4096 Sep 26 16:13 /usr/local/nagios
drwxrwxr-x 4 nagios nagios 4096 Dec 13 10:40 /usr/local/nagios/var
drwxr-xr-x 2 nagios nagios 49152 Dec 12 23:59 /usr/local/nagios/var/archives/
The permissions look fine. On my "stock" Nagios Core machine though, the archives folder is group-writable. I am not sure if this is going to make a difference, but you could run:
chmod g+w /usr/local/nagios/var/archives/
to see if this is going to help.
Did you forget to upload the nagios.cfg file?
breddydu
Post by breddydu »
Permissions are same earlier as well when it was working fine, Suddenly it stopped working .
Could you please let us know the solution for this .
Can you upload your main conifg file on the forum (nagios.cfg)?
breddydu
Post by breddydu »
Hello Team,
Please refer the attached nagios cfg file.
Nagios process is running in thre numbers.
19531 nagios 20 0 31988 8840 996 R 100.0 0.2 4765:34 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
31667 nagios 20 0 36236 9196 1288 R 100.0 0.2 3349:04 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
24165 nagios 20 0 32048 116 16 R 100.0 0.0 6195:41 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
12251 nagios 20 0 32020 9100 1180 R 93.9 0.2 503:12.77 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
Also untill we restart the nagios service , Log file is not rotating ever day.
nagioscfg.txt
(46.52 KiB) Downloaded 211 times
What is the command that you ran to obtain the output below?
Do you have multiple instances of nagios running on this machine?
What is the output of the command below?
ps -ef | grep nagios.cfg | grep -v grep
Are you using check_mk? What is in the "check_mk.d" directory?
# added by setup.sh of check_mk
cfg_dir=/usr/local/nagios/etc/check_mk.d
breddydu
Post by breddydu »
Thank you for your reply.
Yes we have multiple instance running on the server.
Output of the command given by you.
[root@HT-Nagios-Tools1 var]# ps -ef | grep nagios.cfg | grep -v grep
nagios 3610 1 0 07:57 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 3618 3610 0 07:57 ? 00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 4458 1 31 Dec17 ? 06:21:23 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 4466 4458 0 Dec17 ? 00:00:03 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 12251 1 69 Dec16 ? 1-04:17:46 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 12259 12251 0 Dec16 ? 00:00:04 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 19531 1 85 Dec13 ? 4-03:18:41 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 19539 19531 0 Dec13 ? 00:00:08 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 24165 1 86 Dec12 ? 5-03:08:39 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 24173 24165 0 Dec12 ? 00:00:26 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 31667 1 77 Dec14 ? 3-03:40:50 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 31675 31667 0 Dec14 ? 00:00:08 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
Yes we are using check_mk
You should not have multiple instances of nagios running on the same machine... Normally, the output should look like something like this:
nagios 45828 1 0 Dec17 ? 00:03:23 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios 45842 45828 0 Dec17 ? 00:00:03 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
You will need to run:
service nagios stop
killall -9 nagios
service nagios start
and check again how many nagios processes are running.
Also, you can temporarily stop using check_mk to see if this is going to fix the issue.
