How does check interval happen after hard state
grayloglearn
Post by grayloglearn »
Hi Team,
There is service or host which is happening check interval every 5 min and retry interval 1 min and max checks 5 times
If any service is down it will check every 1 min and 5 times hard state.
Ex: service is having issue at 10:00AM
Service will check every 1 min and 5 times. 10:05AM.
If service will up at 10:30, in between 10:05 to 10:30 how many times service will poll to check the status?
mbellerue
Re: How does check interval happen after hard state
Post by mbellerue »
After a service is in a HARD down state, Nagios resumes the normal check interval, rather than the retry interval. And since the service is already in a HARD down state, it does not need to go through the retries to ensure that it is down.
Here's a document that explains it in greater detail.
https://assets.nagios.com/downloads/nag ... uling.html
