After NRPE Upgrade
tinut89
After NRPE Upgrade
Post by tinut89 »
All services are showing OK status but load service or check I need to do a reschedule to get that active.
What is fix for this?
Or please provide the curl call to forcefully reschedule the load service for all the machines.
Regards
Tinu
benjaminsmith
Re: After NRPE Upgrade
Post by benjaminsmith »
Hi Tinu,
A couple of questions to help us troubleshoot this for you.
1. Please post a screenshot of the error message you're seeing the Nagios user interface.
2. Log in as nagios user ( su - nagios ) and run the full check command from terminal. Post the full check command and output to the thread.
Thanks.
