This is regarding NTP service. NTP service definition is using the command check_ntp_time command.
It's usage is
./check_ntp_time -H $HOST -w $WARN -c $CRIT
We are getting different results for different hosts.
For example host1
[nagiosserver]# ./check_ntp_time -H host1 -w 1 -c 5
CRITICAL: No response from NTP server
and for host2
nagiosserver]# ./check_ntp_time -H host2 -w 1 -c 5
NTP OK: Offset -6.794929504e-06 secs|offset=-0.000007s;1.000000;5.000000;
Showing correct results for host2
what needs to be configured on host1 to make it working for host1.
check_ntp_time
Re: check_ntp_time
Maybe there is something blocking your Nagios server from communicating with host1? You can try this command,
It should return that the port is open.
nmap -sU host1 -p 123As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Re: check_ntp_time
I tried the command
Getting following error.
-bash: nmap: command not found
#which nmap
no nmap in (paths)
Please suggest
#which nmap
no nmap in (paths)
Please suggest
Re: check_ntp_time
You should be able to add the command with
then you can run the commands above
yum install nmap -y
