Error while opening a page in Support Forum
Srinija544
Moderator Note: Content removed per request
Re: Error while opening a page in Support Forum
This Customer Support forum post has the following as an option:
1. Make a backup of your original plugin:
2. Download the zip file below:
unzip it, and copy over the plugin to the "/usr/local/nagios/libexec/" directory, overwriting the original plugin.
cp -p /usr/local/nagios/libexec/check_mongodb.py /usr/local/nagios/libexec/check_mongodb.py.backupYou do not have the required permissions to view the files attached to this post.
Srinija544
Hi scottwilkerson,
Thanks for the wonderful plugin.
It works very well. All the secondary mongo servers issues are solved successfully.
Regards,
Srinija
Regards,
Srinija
Srinija544
We can close this request. Thanks again
Locking threadSrinija544 wrote:We can close this request. Thanks again
