question about time periods
benhank
Post by benhank »
am I doing this incorrectly? :
i want monitoring to run from 1am to 11am and then from 1200 noon till 11pm
define timeperiod {
timeperiod_name fenway-cx-380 SPB
alias Epic Backup Testing
thursday 01:00-11:00,12:00-23:00
wednesday 01:00-11:00,12:00-23:00
friday 01:00-11:00,12:00-23:00
saturday 01:00-11:00,12:00-23:00
sunday 01:00-11:00,12:00-23:00
monday 01:00-11:00,12:00-23:00
tuesday 01:00-11:00,12:00-23:00
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: question about time periods
Nope, do it like this
define timeperiod {
thursday 12:00-23:00
wednesday 12:00-23:00
friday 01:00-11:00
friday 12:00-23:00
saturday 12:00-23:00
sunday 01:00-11:00
sunday 12:00-23:00
monday 01:00-11:00
monday 12:00-23:00
tuesday 01:00-11:00
tuesday 12:00-23:00
benhank
Post by benhank »
my next son\daughter will be named scottwilkerson...( ok jk but it's the thought that counts)
Proudly running:
Nagios Fusion
:oops: :lol: :oops:
benhank
Post by benhank »
do I have to do that manually on the cfg file? nagios wont let me inset the same day twice in the timperiod cfg manager
Proudly running:
Nagios Fusion
By golly you are right.
You have 2 choices. First would be to add it to a file in
/usr/local/nagios/etc/static
Or, you could install the New CCM Beta which allows multiple entries.
It is available in this post
http://support.nagios.com/forum/viewtop ... 253#p24253
benhank
Post by benhank »
I am going to install the new ccm on my test server (put a beta on production = financial hardship). so your saying to create TWO cfg files or one cfg file and then import it.
Does this mean that nagios can process a file configured the way you said to do it, but the cfg wiz just wont let you do it?
Proudly running:
Nagios Fusion
benhank wrote:so your saying to create TWO cfg files or one cfg file and then import it.
Actually, forget what I said about puting it in the static directory, not the right idea for this. Best to create 1 config and import it.
I just have to say that you may run into issues editing it with the current CCM.
Just one config file, and if you place it in the static directory you
benhank wrote:Does this mean that nagios can process a file configured the way you said to do it, but the cfg wiz just wont let you do it?
Current CCM just doesn't let you do it, but nagios will.
benhank
Post by benhank »
thanks scott
Proudly running:
Nagios Fusion
