Dear all,
how far can the look and feel of NAGIOS XI be customized to the look-and-feel of a company. I found the CustomerLogo component which works as expected and replaces the logo. Still the logo size does not fit into the window and the colors of NAGIOS XI do not match. Also I would like to limit the menus offered to certain users. Also the login page should be customized and the footnote with the link to the version check.
I would be happy for any information on those topics.
Many tx in advance, Klaus.
Customize Logo, Colors, Menus, ..
Re: Customize Logo, Colors, Menus, ..
The only supported interface change is with our components, which at the moment can only customize the logo. If you need more than that, the source for most of the interface is available for modification, although you may not redistribute modified copies and we won't support any problems resulting from your changes.
