Hi All,
We have Nagios XI installed in our environment and we need to monitor Tru64 and OpenVMS nodes. Could some one please share the information of which plugins are available to monitor the mentioned Operating Systems. I could find a web link(www.sefaz.mt.gov.br/) for Tru64 information but that doesn't open.
Please help here.
Regards
Vishal
Nagios Plugins for Tru64 and OpenVMS
Re: Nagios Plugins for Tru64 and OpenVMS
Hey @vishal313, welcome to the forums!
Oof! Tru64 and OpenVMS. That's going to require some work. If you have a mixed CPU architecture environment, you will need to compile the agent and plugins at least once for each CPU architecture, and maybe once for each OS...? I'm not entirely sure on that last part. I know OpenVMS is Unix compatible, but I don't know how much that helps in running binaries between Tru64 and OpenVMS.
That's going to be the first place to start. Compiling the plugins and the agent, and making sure that they work in your environment.
The source code for the plugins can be downloaded here,
https://www.nagios.org/downloads/nagios-plugins/
The source code for the NRPE agent can be downloaded here,
https://github.com/NagiosEnterprises/nrpe/releases
Also, the instructions on this page are for various distros of Linux, FreeBSD, and Solaris, but maybe some of the instructions will translate to Tru64 and/or OpenVMS.
https://support.nagios.com/kb/article.php?id=515
Thank you mbellerue,
I was trying to search a direct set of plugins for Tru64 and OpenVMS.
I will try to work on the suggestions provided by you.
Regards
Vishal
Regards
Vishal
@vishal313, do you have any further questions? Please let us know if it is OK to close this topic now.
We can close this topic. Thank you @mbellerue for your inputs.
benjaminsmith
Great. Thank you for using the Nagios Support Forum.We can close this topic. Thank you @mbellerue for your inputs.
