hI ALL,
What are the best most 10 important points to be considered while implementing "Nagios XI Monitoring" in any
organization
Thanks and Regards
Best way to Implement Nagios XI
benjaminsmith
Re: Best way to Implement Nagios XI
Good question. I will try to answer that by providing some links to some helpful articles and videos, and then just let me know if you have further questions. You'll want to make sure you set up your configurations so they are easy to manage and think about the performance aspects of the check settings. This will pay off as you grow the number of hosts and services in your network.
1. Use contact groups to manage notifications
Nagios XI - Groups
2. Set your check intervals only as often as needed
Nagios XI Check Interval Considerations
3. Master assign service checks by hostgroup
Pro Tip Video
4. Use the bulk host cloning and import wizard to quickly add large numbers of hosts
Using Bulk Host Cloning and Import Wizard
5. When available, use the configuration wizards to save time
Nagios XI Configuration Wizards
6. Follow the guidelines to set the performance settings on the server ( Admin > System Config > Performance Settings )
Maximizing Performance In Nagios XI
7. Use the Bulk Modifications Tool to make changes on more than one host or service
Nagios XI - Core Config Manager - Bulk Modification Tool
8. Optimize the PHP settings
Nagios XI - Optimizing The PHP Settings File
Reference:
https://support.nagios.com/kb/category.php?id=164
Nagios XI - Groups
Pro Tip Video
Reference:
