Hello!
Is it possible to have a control over the amount of data points displayed on the performance graphs?
If several 1-year graphs are displayed, there may be much more then 100,000 points over 600px, making the local machine overload.
Regards,
Nick
Highcharts data point amount
Re: Highcharts data point amount
There's not much that can be done once the data is in the rrd files, but I think the /usr/local/nagios/etc/pnp/rra.cfg can be modified to hold less frequent(fewer) data points with a simple edit from:
To:
This would only affect newly created RRDs so you may want to remove the old perfdata files in /usr/local/nagios/share/perfdata/<hostname>/ so new ones can be created.
# PNP default RRA config
# you will get 400kb of data per datasource
# 2880 entries with 1 minute step = 48 hours
RRA:AVERAGE:0.5:1:2880
# 2880 entries with 5 minute step = 10 days
RRA:AVERAGE:0.5:5:2880
# 4320 entries with 30 minute step = 90 days
RRA:AVERAGE:0.5:30:4320
# 5840 entries with 360 minute step = 4 years
RRA:AVERAGE:0.5:360:5840
RRA:MAX:0.5:1:2880
RRA:MAX:0.5:5:2880
RRA:MAX:0.5:30:4320
RRA:MAX:0.5:360:5840
RRA:MIN:0.5:1:2880
RRA:MIN:0.5:5:2880
RRA:MIN:0.5:30:4320
RRA:MIN:0.5:360:5840
RRA:LAST:0.5:1:2880
RRA:LAST:0.5:1:2880
RRA:LAST:0.5:1:4320
RRA:LAST:0.5:1:5840Code: Select all
RRA:AVERAGE:0.5:720:5840
RRA:MAX:0.5:1:2880
RRA:MAX:0.5:5:2880
RRA:MAX:0.5:30:4320
RRA:MAX:0.5:720:5840
RRA:MIN:0.5:1:2880
RRA:MIN:0.5:5:2880
RRA:MIN:0.5:30:4320
RRA:MIN:0.5:720:5840
RRA:LAST:0.5:1:2880
RRA:LAST:0.5:1:2880
RRA:LAST:0.5:1:4320
RRA:LAST:0.5:1:5840As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Thanks for the idea, but decreasing data points in the rrds is not accepable for us, we still need to dig in with a good detalisation. Removing of the old data would be a disaster btw.
I thought I may be able to modify the highchart php in order to decrease the amount of the displayed data points, but I don't know where to start.
Redards,
nj
Redards,
nj
Note that with the previous suggest that the 1, 5, and 30 minute data would still be available.
That said, there doesn't appear to be a single file or setting to control how many data points are used in a graph.
