hi team,
i would like to see wat causing the swap usage to get filled every 2nd day.
i have attached the system profile report to this. kindly check and let me know so that we can make the appropriate changes.
[root@cvrmnagiosxi001 var]# free -m
total used free shared buff/cache available
Mem: 16046 9682 1426 871 4937 5112
Swap: 2047 2047 0
swap usage is getting filled
IT-OPS-SYS
Re: swap usage is getting filled
It looks like rsyslogd is taking up the largest chunk of memory, by far. Do you have the Nagios server sending its logs to another server?
IT-OPS-SYS
yes, we have secondary server setup for backing up the server
It might be worth checking to make sure that the remote server is getting the logs from your Nagios server. I know that rsyslog will hold a certain number of logs in cache when it cannot contact the remote server. That may be why rsyslog is using up your memory.
