I've configured NagiosXI and the switch for SNMPV3. Bandwidth for all ports and Ping are up but all of the Port Status' report "UNKNOWN - No info is being retrieved."
I've downloaded from hp their most current MIB's for the Procurve J9775A. I've updated Plugin's and Configuration wizards.
Below I've attached the logs for the "Unkonwn Traps Logs" and the MIB's I uploaded to NagiosXI.
What should my next steps be?
Thank you for your help!
Andrew McNeur
HP Procurve J9775A SNMPV3 Port Status "Unknown"
Re: HP Procurve J9775A SNMPV3 Port Status "Unknown"
I took a look at the MIB file is it looks to be corrupted.
If you look at the bottom of it, you will see HTML code and and there are other corrupted data throughout the file.
Get a new copy of the MIB file and verify that is is a good copy and re-upload it to the server after removing the bad copy.
You also need to find this MIB file "HP-ICF-OID" and upload that MIB file before you upload the HP-ENTITY-POWER-MIB MIB file as it is needed to decode the OID's.
