Nagios Map no color green and red lights error
srv.nagios
Post by srv.nagios »
Hello Nagios Community!
Please help me to fix my errors. No color lights in my nagios map (red/green). :(
I have no idea how to fix it. I didn't change any codes.
Thank you so much in advance!
Re: Nagios Map no color green and red lights error
What is the current status of the hosts? No color generally means pending
srv.nagios
Hello thanks for the reply @scottwilkerson
The Localhost is UP but no color on the circle.
You can see my attached file. My map have a four downs(red text) my concern is no color on the circles it means the status is pending but it all UP by the way.
srv.nagios
scottwilkerson wrote:What is the current status of the hosts? No color generally means pending
Current status of the hosts is UP but it say Pending(no color), you can see the attachment 4 red lights mean Down and the others are UP but status is pending(no colors) . My problem is the small circles in my map have no color but the status is UP/DOWN.
I only migrated the nagios core from virtual server to physical server then it comes the error like this.
btw thanks for replying :D
mbellerue
Post by mbellerue »
Can you give us the output of ls -lh /usr/local/nagios/share/images/ ?
srv.nagios
mbellerue wrote:Can you give us the output of ls -lh /usr/local/nagios/share/images/ ?
This is the output.
If you have any idea & recommendation about this error is highly appreciated. thanks a lot!
tacolover101
Post by tacolover101 »
ls
only shows the files, nothing to do with the attributes or permissions. could you please run what @mbellerue mentioned?
srv.nagios
tacolover101 wrote:
ls
Oh so sorry.
This is right one?
What version of Nagios Core are you using and what OS and release is it running on?
srv.nagios
tgriep wrote:What version of Nagios Core are you using and what OS and release is it running on?
Nagios Version installed : Nagios® Core™ Version 4.4.5, August 20, 2019
OS : CentOS Linux 8
