New Script to check jobs returning Blank from Nagios Check
kwhogster
Post by kwhogster »
Trying to write a script so that Nagios can check My Veeam Backup Copy Jobs
My command line
/usr/lib/nagios/plugins/check_nrpe -t 50 -H TGCS008 -c  checkveeamcopy -a 'Exchange Backup Copy Job'
My Nsclient.ini
; check veeam copy jobs
checkveeamcopy = cmd /c echo scripts/powershell/check_veeam_backups.ps1 "$ARG1$" "$ARG2$"; exit $LastExitCode | powershell.exe -command -
When I run it from my command line on the Nagios server I get a blank return.
root@nagios017:/usr/local/nagios/etc/objects/windowsservers# /usr/lib/nagios/plugins/check_nrpe -t 50 -H TGCS008 -c checkveeamcopy -a 'Exchange Backup Copy Job'
My powershell script
$name = $args[0]
if ((Get-PSSnapin -Name VeeamPSSNapin -ErrorAction SilentlyContinue) -eq $null)
    Add-PSSnapin VeeamPSSNapin
$JobNames = Get-VBRJob -Name $name
    foreach ($JobName in $JobNames) {
    $Job = Get-VBRJob -name $JobName.Name
    $LastSession = $Job.FindLastSession()
    $Name = $Job.Name
    $Status = $LastSession.State
    $Progress = "$($LastSession.BaseProgress)%"
    $results += New-Object PSObject -Property @{JobName = $Name; Status = $Status; Progress = $Progress;}
    $results
When I run the powerhell script manually
PS C:\program files\nsclient++\scripts\powershell> .\check_veeam_backups.ps1 'Exchange Backup Copy Job'
Status Progress JobName
Idle 100% Exchange Backup Copy Job
Any ideas
Thank you
Tom
cdienger
Re: New Script to check jobs returning Blank from Nagios Che
Post by cdienger »
Try moving $results outside of the foreach loop and adding an exit code:
    $name = $args[0]
	$results = ""
        $Name = $Job.Name
	$results
	exit 0
kwhogster
Post by kwhogster »
$name = $args[0]
    $Name = $Job.Name
$results
exit 0
Same results from the Nagios server command line just returns blanks
From powershell works fine.
cdienger
Post by cdienger »
The line:
$results = ""
is missing in your updated script. Make sure it is added outside of and above the scope of the foreach loop.
kwhogster
Post by kwhogster »
root@tgcs017:/usr/local/nagios/etc/objects/windowsservers# /usr/lib/nagios/plugi
No output available from command (checkveeamcopy).
Now I get this
I just want to verify that if you run the script manually, is the first line a blank line?
If so, then the powershell script needs to be written to not do that as the first line is sent back to Nagios as a blank, it will show as a blank line in the GUI.
kwhogster
Post by kwhogster »
Guys I got this working now.
changed the "$results = """ to this write-host $Name $Status $Progress $LastResult
I would like to post this script so that other can use this as a plugin.
Can you tell me how I can do that?
Thank you
Tom
The Nagios Exchange site is where you would post the Powershell script.
https://exchange.nagios.org/
Create a login, upload and document the plugin and after it is reviewed, it should be enabled for others to download.
kwhogster
Post by kwhogster »
Thank you
I will document it and post
You can lock this one as resolved.
Tom
Your Welcome.
Closing the post.
