How to monitor Database Blocking sessions
Pratapa
Post by Pratapa »
How to monitor Database Blocking sessions.
Is there a plungin for this.If yes, Please provide the plugin.
Regards,
Pratapa
Re: How to monitor Database Blocking sessions
What kind of DB are you talking about - MSSQL, Oracle, etc.?
Pratapa
Post by Pratapa »
It is Oracle database.
The older check_oracle_health plugins didn't have a "blocking-session" mode, but the newer ones do:
https://labs.consol.de/nagios/check_ora ... index.html
From the changelog:
3.2.1 - 2019-10-10
add mode blocking-sessions (Thanks dbmasters.at for the sql)
You could backup your "old" plugin (just in case), then download, and compile the latest version (3.2.1.1) on your nagios machine. Test it from the command line to make sure it works. You could run something like this:
/usr/local/nagios/libexec/check_oracle_health --connect 'x.x.x.x:1521/yyyy' --username 'username' --password 'password' --mode sql --name="select count(*) from Gv\$"$"session where blocking_session is not NULL order by blocking_session" --warning 50 --critical 200
or
/usr/local/nagios/libexec/check_oracle_health --connect 'x.x.x.x:1521/yyyy' --username 'username' --password 'password' --mode sql --name="select count(*) from v\$session where blocking_session is not NULL order by blocking_session" --warning 50 --critical 200
