In Nagios GUI getting Critical error for HANA DB status
dheerushops
Post by dheerushops »
From https://exchange.nagios.org/directory/P ... se/details.
I have downloaded check_hdbnameserver.py and configured this in nagioshost. But, In Nagios server GUI.
For alert SAP HANA DB HDBName Server getting below error message.
HDBnameserver
UNKNOWN 01-09-2020 10:57:51 0d 0h 0m 24s 3/3 UNKNOWN - is .We can not identify process status
dheerushops
Re: In Nagios GUI getting Critical error for HANA DB status
Below outputs from nagiosserver and nagioshost.
[root@nagioshost libexec]# pwd
/usr/local/nagios/libexec
[root@nagioshost libexec]# ls -lh check_hdbnameserver.py
-rwxrwxr-x 1 nagios nagios 1.4K Jan 9 08:19 check_hdbnameserver.py
[root@snchbwatd11 libexec]#
[root@nagiosserver libexec]# pwd
[root@nagiosserver libexec]# tail /usr/local/nagios/etc/services.cfg
host_name nagioshost
service_description HDBnameserver
check_command check_nrpe!check_hdbnameserver.py
check_hdbindexserver.py
Please check
(1.35 KiB) Downloaded 285 times
Post by Box293 »
The first step is to test the plugin directly on your host, this will remove NRPE from being a problem.
Please show us the command used to test the plugin and the output from the plugin.
dheerushops
[root@nagioshost ~]# /usr/local/nagios/libexec/check_nrpe -H localhost -c check_hdbnameserver.py
tacolover101
Post by tacolover101 »
dheerushops wrote:[root@nagioshost ~]# /usr/local/nagios/libexec/check_nrpe -H localhost -c check_hdbnameserver.py
can you please take nrpe out of the equation, and run the check_hdbnameserver.py script with the needed parameters? then, let us know the result.
dheerushops
[root@nagioshost ~]# /usr/local/nagios/libexec/ -H localhost -c check_hdbnameserver.py
-bash: /usr/local/nagios/libexec/: Is a directory
What was being asked is can you run check_hdbnameserver.py on the remote server to see what the response is.
dheerushops
[root@nagioshost libexec]# check_hdbnameserver.py
-bash: check_hdbnameserver.py: command not found
I think you meant to run
./check_hdbnameserver.py
You need to be able to get the plugin to work correctly (and giving you expected output) on the remote server before trying to make it work through NRPE
