Monitor Cisco Catalyst 6509 port traffic ...
There're about 300 ports on the Cisco Catalyst 6509, when using wizard to setup port traffic monitoring, there seems can only setup 127th ports?
Re: Monitor Cisco Catalyst 6509 port traffic ...
On larger devices, the PHP settings need to be increased.
Do this to increase the memory and timeout values that PHP uses, follow this procedure.
Edit the /etc/php.ini file and change the following from
to
add this to the bottom of that file (If it exists, increase it)
Save the file
Then edit this file
Save the file and restart Apache for the changes to take affect.
service httpd restart
If the above variables have been changed already on the server to values larger than the examples, increase them further.
Run the wizard again and you should see all of the ports.
max_execution_time = 30
max_input_time = 60
memory_limit = 128MCode: Select all
max_execution_time = 120
max_input_time = 240
memory_limit = 2048MCode: Select all
max_input_vars=100000Then edit this file
/etc/httpd/conf/httpd.confCode: Select all
LimitRequestLine 100000service httpd restart
tgriep wrote:On larger devices, the PHP settings need to be increased.
Edit the /etc/php.ini file and change the following fromtoCode: Select all
max_execution_time = 30 max_input_time = 60 memory_limit = 128Madd this to the bottom of that file (If it exists, increase it)Code: Select all
max_execution_time = 120 max_input_time = 240 memory_limit = 2048MSave the fileCode: Select all
Then edit this fileadd this to the bottom of that fileCode: Select all
/etc/httpd/conf/httpd.confSave the file and restart Apache for the changes to take affect.Code: Select all
attachment is the profile.
I answered in the PM but the max_input_vars option was commented out and that would not allow the option to be increased.
