Is the any options to have full admin access minus the GUI user administration portion only?
Just normal user with all options enabled and full CCM access is missing the following
1) Quick Actions in Overview Tab
2) Command in Advanced Tab
3) View in Nagios Core is available but it shows no access to execute commands.
Please help.
Nagios XI Enterprise version 5.6.9
Nagios Access Levels
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
RHEL 6 & 7
Re: Nagios Access Levels
I think you inadvertently also selected the "Read-only access:" box for the user which would give the behavior you describe.
Yup you are right again. Checked the configuration done by my guys and read only was checked.scottwilkerson wrote:I think you inadvertently also selected the "Read-only access:" box for the user which would give the behavior you describe.
Thanks Scott. Please close the thread.
RHEL 6 & 7
RHEL 6 & 7
Great!rajasegar wrote:Yup you are right again. Checked the configuration done by my guys and read only was checked.scottwilkerson wrote:I think you inadvertently also selected the "Read-only access:" box for the user which would give the behavior you describe.
Locking thread
