Is it possible using Nagios REST API to get last good configuration snapshot and restore it if my current apply configuration (system/applyconfig) failed using API? Is it possible to get the applyconfig command output and see the following?
Total Warnings: 0
Total Errors: 0
Joseph
Nagios XI 5.6.6 REST API get and restore config snapshot
Re: Nagios XI 5.6.6 REST API get and restore config snapshot
Unfortunately neither of these are possible via the API at this time.
If you would like I could submit a feature request and they may get added in a future version.
hi scottwilkerson,
Thank you very much to reply this quick.
Yes, please put this as a feature request for future release.
Joseph
Joseph
Features requested.
