Hi Team,
Kindly require assistance with the below.
Not receiving Nagios XI Alert Notifications, last Notification had been received on the 9th of Jan 2020 at 16:11
Nothing that I am aware of has changed on the system.
Should I attempt to "Test Email Notification" I receive a successful response.
However Warning or Critical Alerts are not received.
This is not being blocked either. Unsure at this point what the cause of this issue might be.
Nagios XI is licensed and has been upgraded to Version 5.6.9
Re: Not receiving Nagios XI Alert Notifications
Hi @Branigan, welcome to the forum!
Can you PM your system profile over to me? You can get it from Admin -> System Profile -> Download Profile
I will take a look at it and see if I can find out why you're not getting notifications.
Can you PM me your latest profile?
Admin > System Config > System Profile > Download Profile, save, and PM me the profile.zip file.
------------------------------------------------------------------------------------------------------------mbellerue wrote:Hi @Branigan, welcome to the forum!
Hi There, Thank you.
I will PM that to you now.
Regards
Branigan.
---------------------------------------------------------------------------------------------------------------------------------------------------lmiltchev wrote:Can you PM me your latest profile?
Hi lmiltchev,
Thank you, will PM to you now as well.
Regards
Branigan.
I believe, the issues is caused by the xi_eventqueue db table being crashed. You have many entries in the mysql log as the one below:
to see if this is going to fix the problem. Read more on the issue here:
https://support.nagios.com/kb/article/n ... es-24.html
and here:
https://assets.nagios.com/downloads/nag ... tabase.pdf
FYI, one of the users, listed in the PDF file (mvnx.monitor) has an invalid email... at least I believe it is invalid...
Please check it out to make sure it is not a mistake.
Please run the repair on the database:200115 8:55:01 [ERROR] /usr/libexec/mysqld: Table './nagiosxi/xi_eventqueue' is marked as crashed and should be repaired
/usr/local/nagiosxi/scripts/repair_databases.shhttps://support.nagios.com/kb/article/n ... es-24.html
and here:
-------------------------------------------------------------------------------------------------------------------------------------------------------------------------------lmiltchev wrote:I believe, the issues is caused by the xi_eventqueue db table being crashed. You have many entries in the mysql log as the one below:Please run the repair on the database:200115 8:55:01 [ERROR] /usr/libexec/mysqld: Table './nagiosxi/xi_eventqueue' is marked as crashed and should be repairedto see if this is going to fix the problem. Read more on the issue here:Code: Select all
and here:
FYI, one of the users, listed in the PDF file (mvnx.monitor) has an invalid email... at least I believe it is invalid...Please check it out to make sure it is not a mistake.
Thank you kindly for the assistance @lmiltchev, Issue resolved.
I had initially only run the "/usr/local/nagiosxi/scripts/repairmysql.sh nagios" command.
Our site did experience a Power Outage prior to this issue so it makes sense.
The mvnx.monitor account was added for testing purposes. Intentionally did not add a valid email address.
Great!
Locking thread
Locking thread
