Nagios XI – Installing The Linux Agent
lntinfo
Post by lntinfo »
for monitoring RHEL server under nagiosxi do we need to have internet download connection for running below commands:
./0-yum
./1-prereqs
./2-usersgroups
./3-services
./A-subcomponents
or those pkgs reside under linux-nrpe-agent.tar.gz
Re: Nagios XI – Installing The Linux Agent
First you should not run then individually, just run ./fullinstall
and YES, you do need an internet connection to install the required packages.
lntinfo
Post by lntinfo »
does that monitoring system require RHN registration ?
on which we are going to install nrpe.
Yes, I do believe you will need RHN registration to install the required packages.
lntinfo
Post by lntinfo »
after i run #./fullinstall below error persist
enterpriseenterpriseserver5.7 is not currently supported. Please use Red Hat or CentOS versions 5 or 6.
here can i go with Nagios XI – Monitoring Linux Using SNMP. if installing agent is not possible with 5.7
We had posted some modifications to the install script yesterday, I'm not positive if they will have any effect on your install but you may want to re-download the agent and try again.
Otherwise certainly you could use SNMP to monitor Linux boxes as well
lntinfo
Post by lntinfo »
can you pls. provide me the link for download the agent
lntinfo
Post by lntinfo »
thanks. i will try and let you know.
