I am trying to upgrade from 5.6.8 to the latest version. I am following the manual update instructions found here (https://assets.nagios.com/downloads/nag ... ctions.pdf) however I am getting the following error after running the last step < ./upgrade >
cp: cannot create regular file `/usr/local/nagiosxi/var/': No such file or directory
Any help would be appreciated.
Re: cp: cannot create regular file `/usr/local/nagiosxi/var/
Is this a "default" (vanilla) setup? Are you using custom paths, proxy, etc.?
Can you post the entire /tmp/nagiosxi/upgrade.log file?
Also, run the following commands and show the output:
ls -la -d /usr/local /usr/local/nagiosxi /usr/local/nagiosxi/var
grep full /usr/local/nagiosxi/var/xiversion
Disregard.
We were connecting to the wrong nagios server. We have an old nagios server and were running the upgrade commands on that server and it obviously wasn't working. When I ran the upgrade on the proper server there were no issues.
I am glad your issue has been resolved! I will be locking this topic now. If you have any further questions/issues, please start a new thread. Thank you!
