I am standing up a new installation of Nagios Core 4.4.5 on a RHEL 7 server to monitor all our RHEL 7 servers.
I am getting the error below and have attached my config files
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov systemd[1]: Starting Nagios Core 4.4.5...
-- Subject: Unit nagios.service has begun start-up
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailman/li ... temd-devel
-- Unit nagios.service has begun starting up.
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Nagios Core 4.4.5
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Copyright (c) 2009-present Nagios Core Development Team and Community Contribu
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Copyright (c) 1999-2009 Ethan Galstad
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Last Modified: 2019-08-20
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: License: GPL
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Website: https://www.nagios.org
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Reading configuration data...
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Read main config file okay...
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Error: Template 'SCServer' specified in host definition could not be not found
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Error: Invalid max_check_attempts value for host 'rhel7workdd.rtord.epa.gov'
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Error: Could not register host (config file '/usr/local/nagios/etc/objects/loc
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Error processing object config files!
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: ***> One or more problems was encountered while processing the config files...
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Check your configuration file(s) to ensure that they contain valid
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: directives and data definitions. If you are upgrading from a previous
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: version of Nagios, you should be aware that some variables/definitions
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: may have been removed or modified in this version. Make sure to read
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: the HTML documentation regarding the config files, as well as the
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: 'Whats New' section to find out what has changed.
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov systemd[1]: nagios.service: control process exited, code=exited status=1
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov systemd[1]: Failed to start Nagios Core 4.4.5.
-- Subject: Unit nagios.service has failed
-- Unit nagios.service has failed.
New Nagios 4.4.5 installation is failing
franchise036
SCServers.cfg.txt- (95.44 KiB) Downloaded 118 times
SCServers-RTP.cfg.txt- (29.91 KiB) Downloaded 122 times
Re: New Nagios 4.4.5 installation is failing
Let's dissect these two lines in the error
SCServer
I would suspect that that template would contain the max_check_attempts that is missing from all of your definitions.
SCServer
the first line states that the template SCServer can not be found. This template is defined to be used in many of the host definitions you have in SCServers-RTP.cfg.txt but neither of the files you posted contain a definition for SCServer and it appears that nagios cannot find it as well.franchise036 wrote:Code: Select all
Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Error: Template 'SCServer' specified in host definition could not be not found Jan 15 15:13:11 rhel7workdd.rtord.epa.gov nagios[28413]: Error: Invalid max_check_attempts value for host 'rhel7workdd.rtord.epa.gov'
franchise036
I can figure out the syntax for this and what file to put it in??
It should looks something like this and can go in any file that is included in the configfranchise036 wrote:I can figure out the syntax for this and what file to put it in??
name SCServer
max_check_attempts 5
check_interval 10
retry_interval 2
check_period 24x7
check_freshness 0
notification_interval 60
notification_period 24x7
notifications_enabled 1
register 0
franchise036
[root@rhel7workdd ORD]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.4.5
License: GPL
Error: Template 'SCServer' specified in host definition could not be not found (config file '/usr/local/nagios/etc/objects/ORD/SCServers-RTP.cfg', starting on line 836)
Error: Could not register host (config file '/usr/local/nagios/etc/objects/localhost.cfg', starting on line 24)
Nagios Core 4.4.5
License: GPL
Did you add the definition example above to a file that is included in the configs?
franchise036
I have added to the SCServers.cfg file what was to be added but nothing changed.
- Box293
- Too Basu
You need a host template defined called 'SCServer'.franchise036 wrote:Error: Template 'SCServer' specified in host definition could not be not found (config file '/usr/local/nagios/etc/objects/ORD/SCServers-RTP.cfg', starting on line 836)
The default config has a templates.cfg file that you can find an example template to copy and turn into the missing template.
