Please excuse if my query appears silly to all you experts out there. My question is
I have set up a demo environmnet with 3 apache web backends behind a nginx loadbalancer and am monitoring them with a nagios server in the same subnet. I used the default standard *.cfg file (for apache web backends and loadbalancer )in /etc/nagios3/conf.d that was already present for localhost( that is nagios monitoring host itself). They contain a host check and 3 service check for disk space, number of users and load. But for some reason all service checks show green , except disk space which is in WARNING status ?with "null" status information.
My first question , how does the nagios host perform these service checks on external hosts without nrpe? ( Is it SNMP , but netstat shows no snmp processes or open 161/162 ports)
Second, what could be the reason for the disk space check giving WARNING with "null" status information
Query regarding Nagios monitoring
Re: Query regarding Nagios monitoring
Welcome to the forums!
https://assets.nagios.com/downloads/nag ... start.html
Also, just to make sure you're going in the right direction, know that we have another agent out there. Nagios Cross-Platform Agent (NCPA). You can check it out here,
https://www.nagios.org/ncpa/
No need to worry about questions being silly or not, all questions are good. Ask questions, we're here to help!JABI786 wrote:Please excuse if my query appears silly to all you experts out there.
Okay, so very first thing here. /etc/nagios3. This tells me that you installed Nagios via the distribution's package manager. With any other application, this is the way to go. However, with Nagios, for some reason those packages never get updated. For example, you've got Nagios 3. We're on 4.4.5. We'll keep helping with what you have, it's still Nagios after all, but I just want to make sure you know that there are improvements to be had. Take a look here if you want to check out 4.4.5.I have set up a demo environmnet with 3 apache web backends behind a nginx loadbalancer and am monitoring them with a nagios server in the same subnet. I used the default standard *.cfg file (for apache web backends and loadbalancer )in /etc/nagios3/conf.d that was already present for localhost( that is nagios monitoring host itself). They contain a host check and 3 service check for disk space, number of users and load. But for some reason all service checks show green , except disk space which is in WARNING status ?with "null" status information.
To answer this we will need the configuration file you mentioned earlier, as well as your commands.cfg file. If you could post those here, I can walk you through what's happening in the service check.My first question , how does the nagios host perform these service checks on external hosts without nrpe? ( Is it SNMP , but netstat shows no snmp processes or open 161/162 ports)
Usually, and this varies from plugin to plugin, when some kind of unknown status is returned, the plugin will return a warning. But that does vary, so for one plugin it may be a warning, another may be critical, and yet a third plugin may return a status of unknown.Second, what could be the reason for the disk space check giving WARNING with "null" status information
Thanks a ton for your reply. Here is the information you requested.
the commands.cfg at /etc/nagios3/ does not have disk space command information. I assume you are referring to the command plugins, hence , pasting the same.
jabir@Nagios-lab:/etc/nagios-plugins/config$ pwd
jabir@Nagios-lab:/etc/nagios-plugins/config$ cat disk.cfg
# 'check_disk' command definition
command_name check_disk
command_line /usr/lib/nagios/plugins/check_disk -w '$ARG1$' -c '$ARG2$' -e -p '$ARG3$'
# 'check_all_disks' command definition
command_name check_all_disks
command_line /usr/bin/sudo /usr/lib/nagios/plugins/check_disk -w 'aaaa' -c 'bbbb' -e
# 'ssh_disk' command definition
command_name ssh_disk
command_line /usr/lib/nagios/plugins/check_by_ssh -H '$HOSTADDRESS$' -C "/usr/lib/nagios/plugins/check_disk -w '$ARG1$' -c '$ARG2$' -e -p '$ARG3$'"
# use these checks, if you want to test IPv4 connectivity on IPv6 enabled systems
# 'ssh_disk_4' command definition
command_name ssh_disk_4
command_line /usr/lib/nagios/plugins/check_by_ssh -H '$HOSTADDRESS$' -C "/usr/lib/nagios/plugins/check_disk -w '$ARG1$' -c '$ARG2$' -e -p '$ARG3$'" -4
jabir@Nagios-lab:/etc/nagios-plugins/config$ cat /etc/nagios3/conf.d/nginx-loadbalancer.cfg
# A simple configuration file for monitoring the local host
# This can serve as an example for configuring other servers;
# Custom services specific to this host are added here, but services
# defined in nagios2-common_services.cfg may also apply.
use generic-host ; Name of host template to use
host_name lb-lab
alias nginx loadbalancer
address 192.168.122.226
# Define a service to check the disk space of the root partition
# on the local machine. Warning if < 20% free, critical if
# < 10% free space on partition.
use generic-service ; Name of service template to use
host_name lb-lab
service_description Disk Space
check_command check_all_disks!20%!10%
# Define a service to check the number of currently logged in
# users on the local machine. Warning if > 20 users, critical
# if > 50 users.
host_name lb-lab
service_description Current Users
check_command check_users!20!50
# Define a service to check the number of currently running procs
# on the local machine. Warning if > 250 processes, critical if
# > 400 processes.
host_name lb-lab
service_description Total Processes
check_command check_procs!250!400
# Define a service to check the load on the local machine.
host_name lb-lab
service_description Current Load
check_command check_load!5.0!4.0!3.0!10.0!6.0!4.0
So the disk space check you've set up for lb-lab tries to execute this command:
A couple things are wrong but the most important is that this check must use NRPE or NCPA to execute on a remote host. I would recommend installing NCPA since it is the newer of the two and has some nice features over NRPE. See https://www.nagios.org/ncpa/getting-started.php#linux for installation steps.
Once that is done you can check out https://www.nagios.org/ncpa/getting-sta ... monitoring. It steps through a few examples of how to integrate it with Core. Roughly, the steps are:
1. Create a command like:
2. Create a service like:
/usr/bin/sudo /usr/lib/nagios/plugins/check_disk -w 'aaaa' -c 'bbbb' -eOnce that is done you can check out https://www.nagios.org/ncpa/getting-sta ... monitoring. It steps through a few examples of how to integrate it with Core. Roughly, the steps are:
command_name check_ncpa
command_line $USER1$/check_ncpa.py -H $HOSTADDRESS$ $ARG1$
}Code: Select all
host_name lb-lab
check_command check_ncpa!-t 'mytoken' -P 5693 -M 'disk/logical/|' -u Gi
}As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
