Nagios don't show graph anymore
jnash
Post by jnash »
i noticed from a couple of days, nagiosxi show the relative graph but empty only. so i don't have any yellow tracking on it. as shown in attachment.
i installed nagiosxi as my first time and for firstly two days it show graph correctly but then i configure other services on it and now nothing was shown.
can somebody show me the way to correct it?
if u need some configuration just ask me and i will provide.
thanks a lot!
jnash
Re: Nagios don't show graph anymore
Post by jnash »
I also notice in "System status" > "Performance Grapher" with a red icon
Run
service npcd stop
killall npcd
service npcd start
Once started it will take some time to catchup...
jnash
Post by jnash »
I notice after a reboot that it was ok. what about the reasons it can be broken at a time?
thanks so much then!
What version of Nagios XI are you using?
jnash
Post by jnash »
latest: Nagios XI 2011R2.4
What type of load does this machine have? Is it over 10?
There is a setting in the
/usr/local/nagios/etc/pnp/npcd.cfg
load_threshold = 10.0
This could be increased if you have multiple processors
After changing you will need to
service npcd restart
jnash
Post by jnash »
Hi scottwilkerson,
thanks for your answer. no the server is running nagiosxi only and load is <1 just rarely 2,5. so maybe it's not that reason.
any different idea?
thanks
I just realized that your previous message said after a reboot it was fine.
Something likely stopped the npcd daemon
jnash
Post by jnash »
and what do u think about the reason?
