SNMP Walk Wizard - Invalid Warning Number Range for OID
john.lancelot
Post by john.lancelot »
Trying to walk and add APC InROW cooler to XI for monitoring.
It read the output of the walk, but on Step 2 it fails to proceed with the Error.
Attached screenshots.
Your Nagios XI installation is up to date.
Latest Available Version: 5.6.10
Installed Version: 5.6.10
Last Update Check: 2020-01-22 09:20:02
SNMP Walk - Version 2.0.0 - Up to date
Re: SNMP Walk Wizard - Invalid Warning Number Range for OID
Hello.
If you are not going to enter Thresholds in the warning and critical fields, you need to change the "Match Type" to None
