Warning: 2 services running
Kxfrancois
Post by Kxfrancois »
We just upgraded our SEP and we not have 2 services running for SEP on every server.
I am getting this in Nagios: 2 services active (matching "Symantec Endpoint Protection") : WARNING
What can I do to fix this issue?
Kerwin
mbellerue
Re: Warning: 2 services running
Post by mbellerue »
What command are you using to get the number of services? Is this running through an agent like NRPE or NCPA?
Kxfrancois
I am running $USER1$/check_snmp_win.pl -H $HOSTADDRESS$ $ARG1$
no running through an agent
Post by Box293 »
From CCM in XI can you use the Test Check Command button from within the service and show us the result.
Kxfrancois
/usr/local/nagios/libexec/check_snmp_win.pl -H biglots -C hello --v2c -n 'Symantec Endpoint Protection'
cdienger
Post by cdienger »
There could be another service matching for some reason. Try the command again but with the "-v" which should show services:
/usr/local/nagios/libexec/check_snmp_win.pl -H biglots -C hello --v2c -n 'Symantec Endpoint Protection' -v
Kxfrancois
There are 2 services with Symantec Endpoint protection in the name. Is there a way to all for multiple services with the same name?
Post by Box293 »
You could try the -N argument:
-n, --name=NAME[,NAME2...]
   Comma separated names of services (perl regular expressions can be used for every one).
   By default, it is not case sensitive.
-N, --number=<n>
   Compare matching services with <n> instead of the number of names provided.
cdienger
Post by cdienger »
Are the names exactly the same? It would be best to use the unique name of the service you want to be monitoring.
Kxfrancois
That worked! Thank you. Please close this ticket
