Nagiosxi notifications were coming from [email protected] I then Changed the acct to [email protected] Most of the alerts have changed but every now and then host relateed alerts come from root! I need to complete the change so they always come from the [email protected] acct. I need them to be consistent any insight would be helpful
Email settings on the server
General Mail SettingsMail Method:
Sendmail
Send Mail From:
Nagios XI <[email protected]>
Redhat 5.5 64 bit
sendmail
Change the Enail acct sending the Notifications
Re: Change the Enail acct sending the Notifications
Are all of your contacts using the
xi_host_event_handler & xi_service_event_handler
in the Host/Service command* as seen in
Configure -> CCM -> Contacts -> Modify
Not too sound real dumb but when I look at the individuals contacts I do not see a place for the uage of xi_host_event_handler & xi_service_event_handler. Im not sure where else to check for that?
Go to Core Config Manager->Alerting->Contacts-><your-contact>->Modify. Under the "Common Settings" tab (Contact Management) you should see something like this:
Ok thanks for the heads Up I made the change just doing the validation for alerts now
