I created a dashboard in NagVis to display on my company's televisions.
After some time; the dashboard returns to the authentication screen (probably because the session has expired)
I performed tests creating a read-only account; and also using "Automatic Login"; but it’s still expired.
Is it possible to make dasboards accessible anonymously?
Or yet; pass some parameter in the url so that it is not necessary to authenticate?
https://my-xi/nagvis/frontend/nagvis-js ... TEST&xxxxx
NagVis - Problems with session expiration
benjaminsmith
Re: NagVis - Problems with session expiration
Hello @ssoliveira
I would try increasing the Timeout Settings go to Admin --> Security --> Session Timeout. Set this to 0 for unlimited. The other option is to try to use the Insecure Logins option, go to Admin --> Backward Integration --> Backend Login Settings
A few helpful posts on settings this up:
https://support.nagios.com/forum/viewto ... 16&t=54045
https://support.nagios.com/forum/viewto ... =6&t=32908
ssoliveira
Hi Benjamin,
In the current Nagios version; the location is different "
" Admin> System Config> Backward Compatibility> Allow Insecure Logins "
I enabled the option "Enable insecure login for this user"; and generated a ticket on the desired user (nagiosreader) by clicking on "Generate new insecure ticket".
After; I performed a test accessing the main page with the user and ticket; and it worked.
OK
https://omitted/nagiosxi/?username=nagiosreader&ticket=omitted
However; I can't access the dashboards with the ticket; the url returns the authentication page.
NON OK
https://omitted/nagvis/frontend/nagvis-js/index.php?mod=Map&act=view&show=100_PRINCIPAL&username=nagiosreader&ticket=omitted-
benjaminsmith
Hi @ssoliveira,
NagVis is an open-source project application that is merged into Nagios XI in an iframe. After doing some testing on my end, it looks you cannot directly go the NagVis page using the backend tickets.
As a workaround you can log in using the backend tickets:
and then view the NagvVis page
http://192.168.0.232/nagiosxi/index.php?username=nagiosadmin&ticket=123
ssoliveira
Hi Benjamin,
There is some possibility that I can access a url inside nagios by passing the user and ticket parameters; + a parameter containing the desired url? so that after access it redirects the desired url;
Similar to what happens when we access a url without being authenticated; and after authenticating; it redirects the desired page.
benjaminsmith
Hi @ssoliveira,
When you say inside Nagios, you are referring to specific map pages withing NagVis, is this correct?
Other than the workaround of authenticating and then going to the desired page, this may need an enhancement submitted as the Nagvis pages are handled differently.
When you increased the session timeout settings, are you still getting a session expired for the auto-login.I performed tests creating a read-only account, and also using "Automatic Login"; but it’s still expired.
ssoliveira
Hi Benjamin,
Yes; the pages we are displaying on the televisions in the NoC rooms are NagVis maps; The computers that display the information on televisions are located in places that are difficult to access; So; when the best solution would be to have a way of passing some token that allows access to the maps without authentication.
benjaminsmith
Hi @ssoliveira,
One more option, and not sure if this works for your environment or not, but you can add the NagVis map to a View, and display the Views in the NOC room.
https://assets.nagios.com/downloads/nag ... -Views.pdf
