2 nagios xi server, one centralize web
marcf
Post by marcf »
I have to monitor two datacenters, each one with a nagios xi server.
Is it possible to centralize all alerts informations on one nagios xi web from those two datacenters ?
benjaminsmith
Re: 2 nagios xi server, one centralize web
Post by benjaminsmith »
Hello @marcf,
We have a product called Nagios Fusion that allows you to view the status information for both Servers from a central application. However, this product does provide notifications.
https://www.nagios.com/downloads/nagios-fusion/
The other option is to used the Inbound / Outbound check capability to transfer the results of one server to the other.
Documentation
Configuring Inbound Checks
Configuring Outbound Checks
marcf
Post by marcf »
Use inbound and outbound can do the trick.
To use that i would have to use passive check ? set up inbound and outbound with NRDP is quite the easy part.
What to do with thousand of service to switch from active to passive ?
benjaminsmith
Hello Marc,
"What to do with thousand of service to switch from active to passive?"
There's a tool to set up the incoming objects within XI. Go to Admin > Monitoring Config > Unconfigured Object. Please see page 5 of the following guide:
Distributed Monitoring With NRDP
Let me know if that answers your question or not.
