Nagios plugin calling cloud env- response extract auth token
gmills
Post by gmills »
Hello, and Happy New Year to you!
I need to create a Nagios Core plugin, that touches the cloud AWS environments, from non-cloud system.
the problem I see is first I need to obtain a auth token, the return response to the first request would be the auth token.
I would take that auth token and use it to access the cloud envs,
is Nagios Core equiped to handle this type of call, I'm still a bit fresh with Nagios. thank you!
Re: Nagios plugin calling cloud env- response extract auth t
Post by Box293 »
Yes.
Basically Nagios just executes commands and only cares about getting back an exit code and some human friendly text.
Everything you explained will need to be scripted into your plugin, Nagios doesn't care about any of that. Things might get complicated if you want to pass information from one check to another, it's entirely up to you as to how you design it.
gmills
Post by gmills »
got it,
thank you!
Post by Box293 »
Great, is it OK to close this thread?
gmills
Post by gmills »
Yes Sir, please close. thank you
