Check Remote Fileage
IT_TECHGENE
Post by IT_TECHGENE »
Hello to everybody,
i'm using NagiosXI and now in our company we want to check the fileage of some Logfiles on our Windows Servers.
I want to ask if somebody knows a Plugin to check the fileage of a Remote Windows Server. I've already found a Plugin but i get always an error of authentification.
Somebody has any solution to check the fileage on remote Servers?
Tanks! :)
IT_TECHGENE
Re: Check Remote Fileage
Ok now I have found a solution by Myselv:
Use the command:
check_nt -H $HOSTNAME -p 12489 -v FILEAGE -l C:/Test.txt
If you get the error Message: Check contains error. Check log for details (or enable show_errors in nsc.ini)
you need to downgrade the version of NSCLIENT, its a Bug of the 0.3.9 version.
You can read this also her:
http://www.nsclient.org/nscp/ticket/480
Bye ;)
Thanks for posting your solution for others.
