Dear Team,
We have configured the AIX 7.2 server for monitoring the basic services. All the services (i.e. Memory, file system and Swap) are getting monitored except CPU. we are getting "No answer from host" for CPU monitoring.
Please help us to resolve the same.
Niklesh
No answer from host for CPU monitoring in AIX 7.2
nagiosnsdl
benjaminsmith
Re: No answer from host for CPU monitoring in AIX 7.2
Hi Niklesh,
Can run the full check command directly from the terminal in Nagios Xi so we can review the command its arguments along with the output messages?
Instructions
Nagios XI - How to Test Check Commands from the Command Line
Instructions
nagiosnsdl
Hi Benjamin,
Thanks for your prompt response, we've read the document and followed the procedure as mentioned. We're getting same response,
Please suggest.
su -c '/usr/local/nagios/libexec/check_snmp_load_wizard.pl -H 172.22.1.1 -C nagios -w 70 -c 80 -f' nagios
No answer from host
benjaminsmith
Hello @nagiosnsdl,
Do you know the specific OID's for CPU usage? Looking at the plugin, it doesn't list AIX as a supported operating system.
https://exchange.nagios.org/directory/P ... ad/details
See:Supported platforms : Windows, Linux/Unix, AS400, Cisco (routers, ASA, Pix, catalyst), HP Procurve, LinkProof, Blucoat, Nokia, Fortinet, Netscreen, HP-UX.
